Author Topic: Info please changing Crank sensor  (Read 1358 times)
3.2 CHARLIE
« on: 14 August 2010, 03:06:27 »
Hello , Please any info on How to change crank sensor on a 3.2 ????? ;D ;)
Re: Info please changing Crank sensor
« Reply #1 on: 14 August 2010, 03:27:22 »
http://www.omegaowners.com/forum/YaBB.pl?num=1259003779
Changes are most of your questions may have allreat got a guide for them.
Worth checking out.
« Reply #2 on: 14 August 2010, 03:28:22 »
« Reply #3 on: 14 August 2010, 03:34:45 »
and just in case I missed anything before you forgot to ask it
http://www.omegaowners.com/forum/YaBB.pl?num=1243594756
Charlie the forum is a wealth of information,
If its not in the listing I have just posted then there is allways the search option, but rather than use the site search option, use the advanced search in google.
Go to the front page of the forum (home page) copy the link and paste in the goole search at the bottom and then put a key word in the top search sector, it's brilliant and finds allsorts.
3.2 CHARLIE
« Reply #4 on: 14 August 2010, 03:35:06 »
and before you start posting about cam belts  ::)
http://shop.omegaowners.com/index.php?main_page=product_info&cPath=3&products_id=7
Hello , My Posts are going up as you said .. Regards . How much for a Cambelt ?? :D :D :D ;)
« Reply #5 on: 14 August 2010, 03:44:43 »
Charlie - your post count is rising nicely matey, a lot of new members think it's impossible as I did at first.  I knew noting about Omega's as such, but now am happy to jump in on resettings the windows, tyre pressures.
I was amazed at what I leart in the guides, so as time went on I boght a timing belt DVD. etc etc
Cambelts come in a kit, gates is one of the 2 recommended on here and they come with a new pulley tensioner.
A good idea at the time is to fit a water pump at the time if you dont know the history of the current one, and an auxilary belt to drive the pump, alternator etc.
top of head figures
Gates kit £80
aux belt £20
water pump £30
