Author Topic: Door locking motor  (Read 1081 times)
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
Door locking motor
« on: 14 August 2010, 13:56:26 »
Hi guys, I'm changing the motor using the excellent guides. However I am stuck trying to remove the clip, which is at the top, ringed red, in picture 8 of Tunnie's helpful 'how to', connecting the bar to the motor.
http://www.omegaowners.com/forum/YaBB.pl?num=1175610013
As it is plastic, I am reluctant to use normal engineering practice, to paraphrase somewhat "If it ain't broke, force it".
Any helpful comments please?
Cheers :y
Welung666
Re: Door locking motor
« Reply #1 on: 14 August 2010, 14:05:51 »
If you mean the white plastic clip then it has an open side, just push it off the metal rod and the rod slides out. Looking at the pic on Tunnies guide the square plastic part pushes towards the door handle and the rod will just drop out. To refit push the rod back in the hole then turn the square part until it clips back on the rod :y
Shackeng
  • Ramsbury
« Reply #2 on: 14 August 2010, 14:10:33 »
Thanks Lee, I'll try that.
Cheers :y :y :y
Shackeng
  • Ramsbury
« Reply #3 on: 14 August 2010, 18:14:22 »
Thanks very much Lee, now all back together & working.
Cheers
Chris :y :y :y
PS, my clip was red!
« Last Edit: 14 August 2010, 18:14:46 by ci643215 »
Welung666
« Reply #4 on: 14 August 2010, 18:34:41 »
Cheers
Chris :y :y :y
Show off ;D ;D ;D
Shackeng
  • Ramsbury
« Reply #5 on: 14 August 2010, 18:42:41 »
