Author Topic: code 41 (tractor)  (Read 1358 times)
hoofing it
code 41 (tractor)
« on: 12 August 2010, 21:34:43 »
Ive got 41 showing boost preasure voltage low.
How do I fix this :y.
I  knew I spoke to soon ;D
Re: code 41 (tractor)
« Reply #1 on: 12 August 2010, 21:37:49 »
Check the boost sensor pipe isn't blocked.
Check sensor is plugged in.
Check wastegate operates freely.
Omegatoy
  • UK
« Reply #2 on: 12 August 2010, 21:52:51 »
if none of the above the sensor could have gone down?
« Reply #3 on: 12 August 2010, 21:56:50 »
Not seen one fail on U25 or X25 engines...
Omegatoy
  • UK
« Reply #4 on: 13 August 2010, 19:47:42 »
neither have i but there is always a first time! :y
hoofing it
« Reply #5 on: 13 August 2010, 21:07:41 »
Just a update.
I took the manifold/EGR valve off cleaned them out replaced all pipes and vac filter and done 30 starts codes gone.
Now 41 has cleared and 96 has popped up so going to try my spare egr valve when im off on tuesday :y
« Reply #6 on: 14 August 2010, 09:50:50 »
Is 96 the EGR out of range? (with 92 being the cruise one?) - sorry, working from memory.
I wouldn't be overconcerned about the 96 one, as there is no feedback circuit, so its all calculated values.  If you have a spare EGR, then may as well use it, and soak the old one in paintstripper ready to swap back again
« Reply #7 on: 14 August 2010, 09:51:07 »
Also, check the vacuums are good :y
hoofing it
« Reply #8 on: 14 August 2010, 21:15:31 »
the bit that puzzles me is it cutting out with or without air-con on. it doesn't always happen eg. if I m slowing to a stop then stop the car lurches just like when you select drive or reverse and almost stalls if I go from drive to reverse the engine stalls and vice versa and will start instantly again. :-/ :-/
I think my g/box is on it last legs I changed oil+filter last week and the magnet was covered in crud. its was changed 8000 miles ago :-/ the oil was burnt
« Last Edit: 14 August 2010, 21:16:31 by hoof »
