Author Topic: Replacement Parts for 1996 2.0L 16V XEV  (Read 1013 times)
R-vin
  • Trinidad, W.I.
  • Best Regards
« on: 17 August 2010, 12:16:23 »
hi,
replacement parts for my car are almost non existent in my country..Trinidad & Tobago W.I.......i have to remove what ever needs changing and take these to the auto supply stores which stock mainly japanese car parts.....and try and find something...
at least once a year i make a trip to miami USA...and in this time i try to find out as much as possible..
does any one have the GM part numbers / does any one know which american car has the same parts
 for things such as :
-Front Disc pads
-Front Rotors
-Rear disc Pads
-Rear disc rotors
-Cam shaft position sensor
-Crank shaft position sensor
-timing belt (mine has 169 teeth and is about 0.984" wide) so far i have seen a 1985 toyota supra L6 engine timing belt to be a substitute.
-timing belt tensioners and guide pulleys
-Air filter, i have seen a 1997 cadillac catera K&N 33-2734 air filter to be a close match.....
-A/C compressor...can a Sanden 508 be substituted??? and if so what drive belt is needed????(currently i use a 6PK1900
-Spark Plugs...what is the correct NGK / Bosch /champion / E3 / Denso spark plug for this engine.... when i bought the car it had Bosch R6.671  FR8LDC4 plugs >>>these are for a Daewoo Leganza...??????
-MAF sensor....
Currently i have a problem when i depress the accelerator...the engine hesitates, probably a mis - fire then revvs...but under smooth controlled acceleration no problem...i got a set of new BOSCH plus 4  plugs that cross refferenced to the Daewoo Leganza plugs i got wit my omega and didnt help much..the engine also got a cheap free flow after market cone filter put into the air box...not much help either....the cam sensor was changed after i got the trouble code for this some time last year...the GM part number could not be retrieved from the old and new part....was like someone who supplies these parts to my country took a soldering iron and passed it over the numbers.....
well i await any and all replys...
Omega Driver Forever
R-vin
R-vin
Re: Replacement Parts for 1996 2.0L 16V XEV
« Reply #1 on: 17 August 2010, 14:55:32 »
hi,
-Front Disc pads Yours are probably 286mm. GM  2.0 to '97
9192123
-Front Rotors Set of discs & pads GM 93175467
-Rear disc Pads  GM 93169001  Rear shoes GM 90541931
-Rear disc rotors  GM 90444513
-Crank shaft position sensor GM 2.0 16v to 14194716 90458251
2.0 16v from 14194717/31000001 9174621
-timing belt tensioners and guide pulleys GM X20XEV to 14195375/31029799 93174260
X20XEV from 14195376/31029800 93174261
-Air filter, i have seen a 1997 cadillac catera K&N 33-2734 air filter to be a close match..... GM All models 91149684
-Spark Plugs...what is the correct NGK / Bosch /champion / E3 / Denso spark plug for this engine.... when i bought the car it had Bosch R6.671  FR8LDC4 plugs >>>these are for a Daewoo Leganza...??????  GM 2.0/2.2 (twin electrode) (GM09) 9195109
-MAF sensor....GM 2.0 16v 90411957
R-vin
Rear discs & pads from (solid) from a Catera will fit as will the air filter. If your front discs are 296mm, Catera will also fit but yours being a `96 model it probably has 286mm
« Last Edit: 17 August 2010, 14:57:17 by RobG »
