Author Topic: crank sensor again  (Read 1349 times)
squid
crank sensor again
« on: 16 August 2010, 22:19:27 »
put my 2001 2.6 mv6 in the garage today to go on diagnostics machine told neede a new crank sensor and that he had ordered the part (without asking me first) i then asked how much it was going to cost he said 130 all in as its a pig of a job is it me or does this sound to high surely a sensor isnt that much so it must be labour thanks.
Welung666
Re: crank sensor again
« Reply #1 on: 16 August 2010, 22:21:18 »
Tell him to keep it! £50 for the crank sensor, £25 for me to fit it!
« Reply #2 on: 16 August 2010, 22:22:20 »
Rip off .. total rip off
Sensor around £60 I think .. time to fit ... well if you read here you'll realise !!
http://www.omegaowners.com/forum/YaBB.pl?num=1174321688
less than 30 minutes on a bad day .. an hour if you remove the scuttle to make it a tad easier access wise
EDIT
Stick your location in your profile .. might be someone who can help close to you ...  :)
« Last Edit: 16 August 2010, 22:24:16 by entwood »
« Reply #3 on: 16 August 2010, 22:23:40 »
these  are Vauxhall prices ... do you have a Trade Club card or access to one?
Omega Part Number Retail Price Normal Trade Trade Club
Crankshaft sensors
2.0 16v to 14194716 90458251 £60.50 £54.46 £47.10
U25TD/X25TD 90487810 £98.50 £88.65 £76.94
2.5 (early models) 90492006 £83.50 £75.15 £65.12
2.5 (later models) 90492061 £61.50 £55.36 £47.88
2.0 8v 90493864 £60.50 £54.46 £47.10
2.0DTi/2.2DTi 90540188 £37.75 £33.98 £29.40
2.6/3.0/3.2 90540743 £55.00 £49.56 £42.63
2.0 16v from 14194717/31000001 9174621 £36.60 £33.00 £28.47
they're not difficult to change, just make sure the cable is routed away from the exhaust.  :y
« Last Edit: 16 August 2010, 22:24:29 by Andy_B »
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #4 on: 17 August 2010, 14:21:53 »
On my V6 petrol cost was £80 fitted
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #5 on: 17 August 2010, 15:31:33 »
For god's sake never ask him to do your cambelt then. ;D ;D
TuBy's new whipping boy.
Dave C
  • Aldershot, Hants
« Reply #6 on: 17 August 2010, 17:53:03 »
Squid,
As Entwood said just follow the guides on the forum, save yourself a shit load of money by not paying labour charges.
Changed the crank sensor on my 2.6 V6 a few weeks ago, I do not have alot of mechanical knowledge, but followed the guide. Took me about 30 minutes, only had one problem where the seal around the sensor was not seated correctly so started to leak oil. Reseated it and so far had no problems.
Just make sure when you route the lead for the new sensor across to the wing make sure it does not touch the pre cat as it passes quite close.
