Author Topic: Wishbone question  (Read 1558 times)
Wishbone question
« on: 08 January 2008, 04:39:32 »
Posting in gen chat, as not Omega related.
I recently changed a pair of wishbones on a Vectra B. The job itself was a peice of cake, about 15 mins per side tops.
The only snag I came across, is that I know they are supposed to be torqued with the car down on the ground.
However, I just couldn't get the bloody access, to get on the bolts!
Is there ANY way of doing this, without a big ramp, or a pit?
Would it be acceptable to drive the cars front wheels up onto ramps to get the clearance, and then do the final torque?
I presume it would, just wanted to check...
IrmscherKris
  • Manchester
  • banned due to bad trader references
Re: Wishbone question
« Reply #1 on: 08 January 2008, 08:29:23 »
Lower it on to some bricks? or a kerb? Jack the wheel up?
« Reply #2 on: 08 January 2008, 08:32:03 »
Can you not tighten with a spanner to stop movement and then jack it back up for the final nip up with the torque wrench.
Dazzler
  • Haverhill, Suffolk
« Reply #3 on: 08 January 2008, 09:53:59 »
Place jack under hub or similar to act as weight on wheels, then torque up as normal.
« Reply #4 on: 08 January 2008, 10:40:04 »
I lower it, tighten up pretty tight with normal rachet, then raise again to get big torque wrench in
« Reply #5 on: 08 January 2008, 11:16:13 »
I can't see any problem with that idea. The weight of the car is on the wheels.
shyboy
  • Southport, merseyside.
    • Mazda 6
« Reply #6 on: 08 January 2008, 11:32:24 »
Many years ago I used to use scaffolding planks and bricks to progressively lever the car to any height up to about 2 feet. Long winded, so probably only worthwhile for long jobs, but it worked a treat.
You also need a bit of space, front and back, as well, of course.
carlos_fandango
  • Stoke On Trent
« Reply #7 on: 08 January 2008, 21:54:04 »
I used an axle stand under the hub, and "very slowly" lowered the jack.
