Author Topic: Rear passenger Air vents (Prefacelift estate)  (Read 1467 times)
MV6Matt
  • London
    • No car since 2022....
« on: 19 August 2010, 09:34:28 »
Hi,
The internal direction blades and cage have fallen back into the body of the rear of the centre console. :(
Haynes suggests I've got to dismantle the centre console to get at them. :-/
Can anyone tell me if there's a different/quicker way?
Any advice or experience - please let me know. :y
Matthew
(thanks Ian)
Welung666
Re: Rear passenger Air vents (Prefacelift estate)
« Reply #1 on: 19 August 2010, 12:19:28 »
Butter knife either side of each vent and they pop out easily. Fish the bits out if you can and re-assemble. If you can't repair them give me a shout as I have a few here :y
MV6Matt
  • London
« Reply #2 on: 19 August 2010, 16:26:06 »
Wellung! Thank you very much - worked a treat!
Is it common for not much cold air to get through to these air vents? Front ones are fine and blow with some force as the fan is increased - hardly seems to be getting through to the back ones.
Do I have a blocked centre console? Is there often poor connection through to here?
Any one know please let me know!
Matthew
(thanks Ian)
MV6Matt
  • London
« Reply #3 on: 20 August 2010, 08:16:44 »
Has anyone experience of checking for potential blockage to the rear vents?
Much appreciated if you have! :y
Matthew :)
(thanks Ian)
Welung666
« Reply #4 on: 20 August 2010, 08:19:02 »
Centre console out is the only way to check the rear vent runs unfortunately.
MV6Matt
  • London
« Reply #5 on: 20 August 2010, 08:49:00 »
Oh Bugger!  >:(
....a job for after the hols then!
Cheers for the info!
Matthew
(thanks Ian)
