Author Topic: 2.2 oil leak  (Read 1080 times)
Iain
2.2 oil leak
« on: 21 August 2010, 15:01:02 »
Ok guys i have just...
Replaced the cam cover gaskets
Removed the metal breather pipe, cleaned it, new gasket
Full service
Now at the base of the metal breather pipe,where it bolts on i have a slight drip of oil....
I get the feeling it is dripping onto there from higher up..
Before i go taking things back off again(thinking cam cover gasket may not be seated properly) has anyone else had this?
mark.adams
  • Cambridgeshire
  • Happy
    • Omega 2.6 V6 Elite
Re: 2.2 oil leak
« Reply #1 on: 21 August 2010, 15:22:55 »
Yep cam cover gasket where the two semi circular bits of gasket fit at the back of the cam cover (typically) did you use any of that black vauxhall sealant?
Omega 2.6 V6 Elite in Shiny Black
Proz
  • Largoward , Fife , Scotland
    • Omega-less now :-/
Re: 2.2 oil leak
« Reply #2 on: 21 August 2010, 15:25:57 »
Unless its the gasket at the bottom of the metal pipe ... it has a ridge and has to be fitted the right way up although i cant remember which way up it is  :-/
But you say its dripping so yes maybe the cam gasket half moons aint sitting properly or maybe just some left over oil  :-/
Iain
Re: 2.2 oil leak
« Reply #3 on: 21 August 2010, 15:26:49 »
I did mate yeah,but thinking back im sure i only put it on the edges, the same as the front! :(
Proz
Re: 2.2 oil leak
« Reply #4 on: 21 August 2010, 15:27:53 »
I never used any of the Vx sealant stuff when i did mine  8-)
Iain
Re: 2.2 oil leak
« Reply #5 on: 21 August 2010, 15:32:09 »
The breather gasket im sure was seated with the dent down(if that makes sense)
Might be the easiest option to try that 1st before pulling off the cam cover again
Proz
Re: 2.2 oil leak
« Reply #6 on: 21 August 2010, 15:37:02 »
Says here the raised part of gasket must face up .... very bottom of the guide  :y
http://www.omegaowners.com/forum/YaBB.pl?num=1162397695
« Last Edit: 21 August 2010, 15:37:45 by Mark38 »
Iain
Re: 2.2 oil leak
« Reply #7 on: 21 August 2010, 16:30:51 »
Job done! ;) :y
Breather pipe right enough... i took it back off cleaned up the old gasket and put that back on.... sorted! :y
Proz
Re: 2.2 oil leak
« Reply #8 on: 21 August 2010, 17:21:12 »
 :y :y :y ::)
