Author Topic: 2001 aircon v6  (Read 2052 times)
vauxhallvauxhall
2001 aircon v6
« on: 22 August 2010, 16:50:13 »
no power to  aircon compressor works if wired seperatley not fuse suspect solonoid but do not know which one or where
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Re: 2001 aircon v6
« Reply #1 on: 22 August 2010, 16:54:10 »
Have you checked it's got enough gas pressure in the system?
It shuts down the feed to the clutch if there isn't.
TuBy's new whipping boy.
vauxhallvauxhall
Re: 2001 aircon v6
« Reply #2 on: 22 August 2010, 16:59:57 »
tried self  refill but this requires pump to be running I will bridge wire pump and try again
fred
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
Re: 2001 aircon v6
« Reply #3 on: 22 August 2010, 17:05:59 »
Those self refill kits are a waste of time and money mate.
Get a real aircon firm to do it.
The system needs to be vaccumed out for about 30 mins to empty it of all the moisture and check for leaks then needs a measured amount of lubricant and a/c refrigerant putting back in. Get them to put uv dye in too so you can trace any leaks in the future.
