Author Topic: 2001 Omega 2.6 V6 - Oil Problem  (Read 3017 times)
StevieP
  • Northamptonshire
« on: 21 August 2010, 16:39:51 »
Hi Guys,
Some advice needed, I have a low mileage (50k) 2.6 V6 which I have recently noticed the following problems:-
1, Burning Oil Smell from Engine
2, Getting through more oil than usual (topping up once a month now)
3, Smokes on initial start up after sitting all night.
There are no signs of any oil leaks on the floor or in the engine that I can see, so baffled as to what could be causing it.
The car still seems to run fine, but I am keen to get this problem resolved ASAP as it might get worse.
Has anyone any ideas of what could be wrong ???? Is my poor car dying ???? Any one local who could resolve the problem at a reasonable cost (Im in Northants).
Any Help / Advice Appreciated
Steve  :(
Re: 2001 Omega 2.6 V6 - Oil Problem
« Reply #1 on: 21 August 2010, 16:58:07 »
Check round the rocker cover gadkeys and in the holes where the spark plugs are.
hotel21
  • The Kingdom of Fife
« Reply #2 on: 21 August 2010, 16:58:20 »
My shout is cam cover gaskets leaking and breathers blocked as this is the most common but you say burning oil on initial startup.  That reads to me as valve stem oil seals.
If confirmed no oil visible on outside of engine/floor then remove one of the coilpacks from one side and see if the plug base is wet with oil.  That would be an indicator of cam cover leak, potentially.
No misfiring at all?
StevieP
  • Northamptonshire
« Reply #3 on: 21 August 2010, 17:01:55 »
No Misfiring that Ive noticed when warm, but only on a couple of occasions when cold.
hotel21
« Reply #4 on: 21 August 2010, 17:06:45 »
That would tie in with stem oil seals leaking then.
When engine running the head & internals are full of oil.  When its switched off the oil drains back to the sump.  Some valves will be partially open and the seals are designed to prevent oil draining into the cylinder.
Pretty sure there was a problem with duff seals on a certain age of 2.6/3.2 but someone will confirm no doubt...
StevieP
  • Northamptonshire
« Reply #5 on: 21 August 2010, 17:11:35 »
That sounds an expensive job .........
Martin_1962
« Reply #6 on: 21 August 2010, 18:53:12 »
Y reg or 51 reg?
You need new valve seals.
I did mine last year, but took the opportunity to port and fit 3.0 cams as well.
I also replaced cam belt and oil cooler as it was basically sensible to do so
  • Auckland
    • Mazda MPV
« Reply #7 on: 21 August 2010, 21:42:56 »
Chances are that any 9 year old Omega has blocked breathers and leaking cam cover gaskets as a result.
Before you do anything else clean out the breathers. It won't stop the cam covers leaking but it should significantly reduce the quantity of lost oil.
If you do have to change the valve stem seals then fit genuine cam cover seals when you put the cam covers back on.
StevieP
  • Northamptonshire
« Reply #8 on: 22 August 2010, 20:21:16 »
The Car is a Y reg Martin, probably worth me trying to get the breathers cleaned and the rocker cover gasket done to see if that is the fault, getting burning oil smell in actual car now, car seems to run fine though.
Anyone near Northants fancy earning some cash to do this ???
If this dosent fix it then, new stem seals maybe next, anyone any idea of how much this is likely to cost ??
Steve :D
Martin_1962
« Reply #9 on: 22 August 2010, 23:33:47 »
Steve :D
Y reg so in the danger periond
It isn't that bad a job, if you can put up with the burnung you could leave it
« Reply #10 on: 23 August 2010, 09:27:44 »
Steve :D
This is the kind of job you can leave until the heads have to come off for something more serious. The seals themselves will only be a quid or so each, it's just the labour invoved in removing the cylinder heads, and all the associated gaskets.
cleggy
« Reply #11 on: 23 August 2010, 11:12:24 »
I have the same problem on a Y reg, Valve Stem Seals. I just ignore it, althought to be honest I don't get the smell of burning oil, just blue exhaust smoke on start up, and a little high oil consumtion. IIRC VX state that a litre per 1000 miles if fine.
manny
  • bromorough.Wirral.
« Reply #12 on: 23 August 2010, 19:39:07 »
My Y reg MV6 smokes on start up. I just live with it. I was told that it is possible to change stem seals with out taking the head off. Is this true?
2001 OMEGA MV6
« Reply #13 on: 23 August 2010, 19:54:47 »
Is the smoke out of the exhaust? If so, stem seals are favourite....
Martin_1962
« Reply #14 on: 23 August 2010, 20:33:38 »
My Y reg doesn't smoke any more, however I did have lambda issues - they were soot covered, and it never burnt off
Page created in 0.031 seconds with 16 queries.
