Author Topic: Mayday, Mayday v6 2.5 sounds tappety  (Read 3951 times)
  • Auckland
    • Mazda MPV
Re: Mayday, Mayday v6 2.5 sounds tappety
« Reply #15 on: 21 August 2010, 16:22:03 »
Presumably you had to undo the nut on the concertina stainless steel pipe between EGR and the exhaust manifold.
I can see that the bolt that goes in the bracket to the EGR is missing. I wonder if the nut on the concertina pipe is loose (or maybe the pipe has cracked?)
I left the nut loose on mine once and the sound wasn't very pleasant  :( but it was quickly fixed by doing the nut up again :y
Vitaliy
  • Knezha, Bulgaria
    • OpelOmega B 2.5 v6 Estate
« Reply #16 on: 21 August 2010, 17:00:40 »
Just checked- nut is fine.
But now for the weird stuff:
after 15 minutes practising yoga i managed to disconnect injection loom ( plug for whole injector set at the back of the nearside head) - and now when cranking - there is NO tappety sound  :question
when injectors are on- its surely loud enough in Idle to be noticeable during cranking.
So my finding: no petrol => no power stroke => no sound
That ( to me ) means it not cambelt or tappets related.
Later one friend with more experience will come to hear it running and than if no reasonable suggestion from him - will try to isolate EGR valve completely and see what happens.
Vitaliy
  • Knezha, Bulgaria
« Reply #17 on: 21 August 2010, 22:09:59 »
I removed EGR and will make a plate to go between egr and inlet manifold to stop any gas passing.
Additionally my friend thinks it has dropped a valve and suggested to do a compression test - will do this before putting EGR valve with blanking plate back in place. ( at least on 3 cylinders below the valve)
Vitaliy
  • Knezha, Bulgaria
« Reply #18 on: 22 August 2010, 13:13:38 »
It has been raining all morning - couldn't even do a compression test.
Blanking plate is ready.
Still wondering what else could happened. Any ideas?
harpersimon
  • Marlow, Bucks
  • Live fast, Die young - leave a good looking corpse
« Reply #19 on: 22 August 2010, 16:07:48 »
Dunno but can I send the plod round with your 120mph admission?  ;D
Vitaliy
  • Knezha, Bulgaria
« Reply #20 on: 22 August 2010, 17:55:50 »
Don't get me wrong - I don't like high speeds - But i am in love with acceleration - that is where i get my adrenalin.   :D
But saying that I believe that one has to be total looser never trying to see how his car goes - even if only once when owing it.
Unfortunately I am paying the price for that - I think I am down to head out job as on right head I have 150- ish PSI on 2 cylinders and 300+ PSI on the front one - no idea what the hell has happened but will have to investigate.
Vitaliy
  • Knezha, Bulgaria
« Reply #21 on: 22 August 2010, 22:56:28 »
Update: I was trying to get to the cambelt today but rain didn't help.
I am doing a bit of a research so any comment will be greatly appreciated.
If I get it to work at least I will need one rocker cover as i believe its slightly bent. I do know this is common problem - should i go for one from vectra and use the older type gasket thats one for head and not separated into two parts?
Than if I end up needing a head - is it same from v6 2.6 newer engine? I would think its not - but still asking. What about other v6 vauxhalls ? anything compatible?
This will help me to decide what to do with the car depending on the damage. I might end up breaking it if damage is too severe.
« Reply #22 on: 23 August 2010, 09:46:17 »
Could be that it's filled with fuel / water / oil?
Might be worth cranking without a plug in it to see if anything comes out?
Vitaliy
  • Knezha, Bulgaria
« Reply #23 on: 24 August 2010, 16:01:05 »
hopefully all is good now - I found the fault - somewhere a needle bearing from old water pump was stuck and while driving fell between timing belt and crank pulley - result is one tooth out on crank - the thing is that there is a correction in measurements - compression on all cylinders is 250 psi +- 2 psi. so valves are not bent. will try to put it right and if compression is good - will do a cambelt change + all pulleys.
Thanks for suggestions.
