Author Topic: Mayday, Mayday v6 2.5 sounds tappety  (Read 3950 times)
Vitaliy
  • Knezha, Bulgaria
    • OpelOmega B 2.5 v6 Estate
« on: 20 August 2010, 20:58:12 »
Hi
I am new to this forum, but not to Omega as a car or other manufacturers forums.
I need urgent advice - I got X reg Omega B facelifted V6 2.5.
I just changed water pump and both rocker cover gaskets as spark plugs were swimming in the oil. Car started and run beautifully with healthy sounding engine. I run it in place for 40 min., maybe more. No troubles, good sound, no overheating oil on cam present in sufficient quantity ( only the one you can see from oil cap), reved it up hard several times . I took it than twice around the block - I couldn't hear the engine, smooth gearchange ( its auto). The way it was driving i would give it 10 out of 10. Than I decided to floor it on a motorway - did 120 MPH without any trouble. than when I was cursing with around 60 back home - i was coming to the junction I had to take - so I released the throttle - for first 10 sec it was allright - but than - started sounding like as if tappets dont get sufficient oil.(I would say sound is coming from the inlet manifold assembly). and it is loud - slightly resembles diesel. still plenty of power, the cam that I can see from the oil cap is still oily as it was before.
Any suggestions please    :'(
Re: Mayday, Mayday v6 2.5 sounds tappety
« Reply #1 on: 20 August 2010, 21:10:20 »
Let it idle for 10-15 mins and see what happens.
Has it had an engine flush recently or a good record of oil changes?
Vitaliy
  • Knezha, Bulgaria
« Reply #2 on: 20 August 2010, 21:18:58 »
yes- oil is reasonably clear and is not thin - it was supposedly serviced 2 weeks ago. and than - it wouldn't just go in one go i think - its as if something fell out of the engine. additionally if it was oil related I dont think i would see that much oil through oil cap.
Abiton
« Reply #3 on: 20 August 2010, 21:45:01 »
Exhaust manifold gasket leak?
I would have thought this would make a farty, blowy noise, but when ours went it was a really nasty metallic clack.
Just a thought.
Vitaliy
  • Knezha, Bulgaria
« Reply #4 on: 20 August 2010, 21:59:06 »
Thank you for quick replies.
I am going to the car to run it for 15 min and see what will happen.
Update: Didn't run it for 10 min - reason sligh misfire  that wasn't  there before the sound changed. with higher RPMs misfire becomes less apparent.
« Last Edit: 20 August 2010, 22:19:46 by Vitasik »
Omegafantasy
  • Oslo, Norway
« Reply #5 on: 20 August 2010, 22:43:36 »
I get flashbacks when I read this  :-[
I had this sound on my last engine and the reason was that the cambelt had slipped quite a bit, although mine did this at very low revs. Hope this isn't the case with yours!
Other reasons I can think of:
- Loose spark plug
- One-way valve for the SAI system broken and blowing exhaust into the rubber hose from the pump (or the hose is off)
- Leaking manifold
You say you've changed the water pump. I hope you did cambelt + tensioners at the same time while you were "in there"?  :y
1995 Omega 2.6 V6 Estate ("fresh" engine) Drives like a 2-litre. Grr! Gettin' dusted by a 1.8 auto Cav..
1991 Omega 3000-24v (major rust job)
(Interested in buying Vauxhall emblems/grille for my V6)
Vitaliy
  • Knezha, Bulgaria
« Reply #6 on: 20 August 2010, 22:52:08 »
I didn't touch the cambelt. Previous owner had it changed by vauxhall 3 month ago and did 2K from then.
Edit: You say SAI valve - where is it ? - is it the thing-y thats in front of the auxiliary belt ?
« Last Edit: 20 August 2010, 22:56:19 by Vitasik »
Omegafantasy
  • Oslo, Norway
« Reply #7 on: 20 August 2010, 23:04:44 »
Yep. One pipe from each manifold joined together in the middle by a valve. Mine popped off once and made a tappety sound, but not so very metallic though.
Vitaliy
  • Knezha, Bulgaria
« Reply #8 on: 20 August 2010, 23:17:17 »
If I cant figure it out tomorrow - will record and post the sound in here.
tomorrow in the agenda:
1. checking spark plugs,
2. checking SAI valve and related hoses
2. Oil pressure test
3. checking timing belt for slipping
wish me luck - I will need it. :-[
Omegafantasy
  • Oslo, Norway
« Reply #9 on: 20 August 2010, 23:29:05 »
Cheer up, it's usually my stuff that goes bad :p I'm not sure how much more I can take, hehe  :)
alank46
  • South Devon
    • 3L Elite Estate 1996
« Reply #10 on: 21 August 2010, 05:32:02 »
Hi
Was the tensioner changed along with the belt?  Its usually the tensioner that fails before the belt.
Alan
Vitaliy
  • Knezha, Bulgaria
« Reply #11 on: 21 August 2010, 14:13:39 »
I have no idea about the tensioner as I am new owner. car still runs. I looked at 3 accessible spark plugs and they are ok, no carbon deposit on them and definitely tight enough. I recorded the sound and will post it in a few minutes.
Vitaliy
  • Knezha, Bulgaria
« Reply #12 on: 21 August 2010, 14:42:31 »
What is this :
I Dont think I have seen this black spot before:
engine sound:
http://rapidshare.com/files/414248685/Sound_clip_05.wav
Sorry for the quality - couldn't find my camera so used my mobile phone.
Omegafantasy
  • Oslo, Norway
« Reply #13 on: 21 August 2010, 14:55:49 »
Somewhat hard to tell from the sound there, but to me it sounds like dry hydraulic lifters.
Vitaliy
  • Knezha, Bulgaria
« Reply #14 on: 21 August 2010, 15:20:05 »
my point exactly, but sound doesn't vary with sides and the cam that you can see from oil cap is oily like it should be - so I assume that it has sufficient oil pressure for lifters. Another thing is that in my opinion sound comes from the inlet manifold (top part of it - i think you have a different name for it). Its too loud to be precise about it though.
Edit: What about that valve thingy - is it possible its responsible?
« Last Edit: 21 August 2010, 15:21:08 by Vitasik »
