Author Topic: Port Reader and MAF Disconnection  (Read 1399 times)
seanjones
  • Sussex coast, near brighton
« on: 17 August 2010, 21:43:19 »
Hi,
My 2002 2.2 16v is struggling to start sometimes, and always runs roughly for a minute or two after starting.  It also on occasion will go into limp mode, with the ECU light on.
Firstly I want to get a read of the fault, and as it goes out after a few restarts I figured I could read it myself. I'm looking at getting an ebay lcd reader thing (item:320502280608).
Has anyone used one/or recommend against it?
Secondly I want to disconnect the MAF sensor to see it that sorts the issue, which is apparently a 10 minute job. I can't find a guide on how to do this, and I'm hopeless without a picture or two of what I need to do. Can anyone help?
Cheers
2002 16v Sport Auto
hoofing it
Re: Port Reader and MAF Disconnection
« Reply #1 on: 17 August 2010, 21:46:19 »
If you update your profile and add your location someone local may be able to help :y
« Reply #2 on: 17 August 2010, 22:35:07 »
Hi,
Cheers
10 minutes???  30 seconds to unplug it - drivers side at front go left from air filter - second plug down - disconnect.  :y
Whoops - sorry disregard location above - thats for a V6 not a 4 pot  :-[
« Last Edit: 17 August 2010, 22:39:00 by dbug »
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #3 on: 17 August 2010, 22:47:09 »
Hi,
Cheers
If you go left, you'll be in the wing!  ;D
EDIT 'Hic'  :D
« Last Edit: 17 August 2010, 22:49:09 by Broomies_Mate »
« Reply #4 on: 17 August 2010, 22:49:55 »
Hi,
Cheers
EDIT 'Hic'  :D
Only a bottle of red wine and 1 pint of bitter - no hics just assumed all oofers drove V6s  :) ;)
Re your edit whoops your right - go right not left - any more edits?? :)
« Last Edit: 17 August 2010, 22:51:30 by dbug »
Abiton
« Reply #5 on: 18 August 2010, 07:56:07 »
See here:
http://www.omegaowners.com/forum/YaBB.pl?num=1279574806
First picture shows MAF plug on the left.  :y
seanjones
« Reply #6 on: 18 August 2010, 08:22:55 »
Scary. I was about to post that link! So I just unplug the wire going into the labelled bit?
2002 16v Sport Auto
seanjones
« Reply #7 on: 20 August 2010, 09:49:24 »
Having unplugged the MAF sensor, my lumping start-up issue has disappeared, having left the car overnight it started sweet as anything this morning. Am I correct in thinking that a new sensor is needed?
2002 16v Sport Auto
Iain
« Reply #8 on: 20 August 2010, 09:53:37 »
Yes mate MAF goosed...
seanjones
« Reply #9 on: 25 August 2010, 10:51:41 »
Well the sensor is replaced, and the start up seems smoother. What. I did notice was that before I unplugged and reconnected the original maf, on startup the car would make a quiet buzzing noise, which it nolonger does. On my old passat that kind of sound was the ecu learning the throttle butterfly positions, could the same be true of the omega?
2002 16v Sport Auto
