Author Topic: Safe to drive with ECU light on?  (Read 1235 times)
MrDJ
« on: 25 August 2010, 08:18:24 »
http://yfrog.com/03ecuaj
Is from the facelift manual and mine is pre-facelift but after unplugging ECU coolant temp sensor and finding I hadn't got a hope in hell of getting it out and plugging back in my light is on.
It doesn't say not safe to drive in facelift manual?
Re: Safe to drive with ECU light on?
« Reply #1 on: 25 August 2010, 08:31:15 »
This is the Emissions light, which comes on when a fault has been detected & a code stored. In this case, when you disconnected the Temp. sensor, it was detected as a broken/faulty signal & the problem code is now stored in the ECU. It is perfectly safe to drive with this particular 'fault'  :y
MrDJ
« Reply #2 on: 25 August 2010, 09:04:22 »
As the sensor is now reconnected how come the light is still on then?
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #3 on: 25 August 2010, 09:35:51 »
It will stay on until you clear the fault codes.
I like red cars
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #4 on: 25 August 2010, 09:36:42 »
Update your profile with your location, someone may live near you that can clear the codes.
I like red cars
MrDJ
« Reply #5 on: 25 August 2010, 09:53:33 »
So fixing the problem wont clear the fault codes?
Also thought I read somewhere 20-30 good starts did that?
« Reply #6 on: 25 August 2010, 11:06:38 »
 ..... quote]
Yes it will. The only time a warning light has to be reset after it's fixed is the ABS light.  ;)
« Reply #7 on: 25 August 2010, 11:09:41 »
No it won't, the light will go out when the fault is corrected. The code will be logged though till cleared or 20/30 'clean starts' have been done.
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
« Reply #8 on: 25 August 2010, 11:51:11 »
As said, fault code lights should go out when the particular fault has been rectified, this doesn't apply to 'saftey critical' systems such as the A.B.S. and S.R.S.
