Author Topic: paint code  (Read 2344 times)
paint code
« on: 23 August 2010, 13:38:50 »
I  know there's a VIN plate description here but I'm buggered if I can work out which my paint code is. So ....... which is it?
(I'll delete the picture later  ;))
Can you detect a wanted post coming up?  ::) ::)
Re: paint code
« Reply #1 on: 23 August 2010, 13:45:08 »
Is your car black :question
Re: paint code
« Reply #2 on: 23 August 2010, 13:48:12 »
yes ...... same colour as the VIN plate  ;)  ;)  ;)  :y
Re: paint code
« Reply #3 on: 23 August 2010, 13:49:17 »
Just seen your wanted post for a black door handle so your paint code Andy is 266,866/81L: Nova Black Met (91-) :y
Re: paint code
« Reply #4 on: 23 August 2010, 13:55:30 »
Ta Rob .... so nothing like the blurb that goes with the VIN http://www.omegaowners.com/forum/YaBB.pl?num=1154543684 I was looking for a code including a Z  .... Y=Paint Type ( Y= Solid Paint, Z = Metallic Paint)
567 = Paint Code
Re: paint code
« Reply #5 on: 23 August 2010, 13:59:20 »
For some strange reason it appears various plates were used http://www.omegaowners.com/forum/YaBB.pl?num=1222004989 :-?
Re: paint code
« Reply #6 on: 23 August 2010, 14:01:18 »
Ah! I didn't know we had that guide, I knew about the one I posted to .... maybe they need sticking together?  ;) :y
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Re: paint code
« Reply #7 on: 23 August 2010, 17:23:46 »
Production date 19990301
80I=Interior Black
81L=Exterior Paint
TuBy's new whipping boy.
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
Re: paint code
« Reply #8 on: 23 August 2010, 17:29:39 »
I always use the id sticker that is revealed when the drivers door is opened...
Brikhead
  • West-Mids.
Re: paint code
« Reply #9 on: 23 August 2010, 17:45:44 »
I have a black Omega and a black Vectra, the colours look identical yet one has Z200 paint code and the other has L20C...
Peevee
  • Ely, Cambridge
Re: paint code
« Reply #10 on: 25 August 2010, 08:25:38 »
Don't take the code as gospel! Two things I've learned in my trade... 1 - the manufacturer's don't always put the right code on the vin plates [ford are the worst on this.. I'm yet to work on a ford that actually has the right paint code stamped on it!]
2 - manufacturer's use the same code for many different shades of the same colour. For instance, I was working on a Corsa the other week with the code 547. This colour has been around since 1990 and as such there are a few shades of this paint. The dealership will tell you it's 547. But it's not until you can put this code against the other shades and then all the shades against the car can you realise just which is the right paint colour and code for your particular vehicle. If you're at all unsure, if you have a friends at a bodyshop who uses colour cards, get them to put the cards relating to your paint code against your car, that way you'll know the right code for your vehicle. This will then help you if you want to get touch up paint from a dealer/distributor etc...
Pvee
Bionic
  • Leicester
  • Why drive anything else?
    • 1999 F/L 3.0 Elite saloon
Re: paint code
« Reply #11 on: 25 August 2010, 11:42:40 »
Same as mine - its 81L (Diamond Black) and because the 81L colour (paint by Lesonal 1K) is an exact match for the paintwork under the trims so it must be correct. Check by using paint swatches at the paint shops because it may change with years of manufacture.
bionic :y
« Last Edit: 25 August 2010, 11:45:56 by its.ray »
Re: paint code
« Reply #12 on: 25 August 2010, 17:36:23 »
Pvee
thanks  :y
Re: paint code
« Reply #13 on: 25 August 2010, 17:37:44 »
.... Check by using paint swatches at the paint shops because it may change with years of manufacture.
bionic :y
thanks, but it'll likely be a rattle can from a motor factor  :( if I can't get hold of the same colour handle  :y
Page created in 0.01 seconds with 14 queries.
