Pages: [1] 2 3  All   Go Down
Author Topic: Tapping / Knocking Noise :(  (Read 5068 times)
SeedyV6
« on: 18 August 2010, 13:35:20 »
I've pulled up at work this morning, switched off the stereo and i hear a tapping / knocking noise. (Teach me to have the bloody stereo so loud, i'd have heard it sooner!) Rev the engine very gently and the noise is consistant with the revs. The noise wasn't there when i fired up this morning.
Car is a 2000 W reg facelift 2.5V6 with 74K on the clock. I bought the car last May. The oil was last changed in May this year. I do not know how often the oil was changed previously however (previous owner swore he looked after it, yeah right!), the garage that serviced the car in May said that the oil that came out was very bad and had appeared not to have been changed in some time.  :(
The lack of oil changes has been confirmed when i took the car to DLK's for rocker gaskets and 3.0 cams.
I only average about 6K a year commuting so I figured on planned oil changes every six months.
Anyhew, at lunch, I've been out and the noise is there from startup but quieter until engine warms up. If you open the bonnet, the noise sounds like it is coming from the top of the engine, say the drivers side bank.
So question is, what am i looking at here? Aside from taking it over to DLK's can I have some best / worse case scenarios please!
I plan on changing the oil this weekend with the vx stuff i just picked up. Was intending to have the sump off and clean out the pickup. Presumably the pick up isn't gonna be pretty considering what the cams looked like when they came out. Another question: Do you need to use the black sealant on the sump? I've picked some up just in case but wanted to know for sure.
Thanks in Advance,
Wes.
PS. Car has plenty of oil at the moment. Oil light goes out on startup and doesn't come on when driving.
« Last Edit: 18 August 2010, 13:56:39 by SeedyV6 »
Re: Tapping / Knocking Noise :(
« Reply #1 on: 18 August 2010, 14:27:16 »
Sounds like it could be a lifter. Might be worth adding some hydraulic lifter treatment to the oil to see if that helps.
SeedyV6
« Reply #2 on: 18 August 2010, 14:42:36 »
Hi Kevin,
thanks for the response. went to halfords straight after vx dealer and dropped wynns version into the oil. was going to see how it goes on the drive home tonight after work. It's about 12-13 miles of mixed driving so i suppose i'll find out soon enough! I am worried though!
R-vin
  • Trinidad, W.I.
  • Best Regards
« Reply #3 on: 18 August 2010, 15:11:29 »
hey,
it seems as if you got some hydraulic lifter problems...
i`ve had similar issues 2 days after i bought my 1996 2.0L 16V XEV GL omega....the day in question i started it normally in the morning and within seconds i heard the light tapping sound, reved the engine and it was consistent with engine rpm...
my solution does not involve drastic engine work...
if you change your own oil  its much easier...
here goes..
perform a motor oil change with a slightly less weight Diesel engine oil and a FRAM PH3387A filter (for 2.0L engine),
run the engine for a few days or so...avoiding harsh accelerations, hi rpm`s...basically take it easy...perform another oil change with a different brand Diesel engine oil and a new oil filter....run the engine again in a similar manner.
(the Fram oil filter can be cut open to inspect for metal/??? from your engine)
perform a final oil change with oil you would usually use in your car and oil filter you are accustomed using.
the reason for the diesel oil....this has a lot of detergents...more than the hi priced brand name stuff claims to clean out your engine....no need for expensive tear downs...and cutting open the oil filters gives you a visual of what is in your engine....
and the tapping sound...it is the cam shaft hitting against the hydraulic lifters above the valves...the hydraulic lifters receive oil pressure and "pump up" that is adjust their height to take up any space between the cam shaft and the lifter...put they do not pump up enough to open the valves...this removes "tappet noise " as was common in older engines...
the problem with your engine is the oil port to one of the Hydraulic lifters is probably blocked, or the oil hole of the lifter is clogged....this is where the diesel oil should wash away any of these sludge/trash in the engine.
its worth a try if you like....of you could do it the long way...remove all of the valve lifters and clean them out thoroughly and reinstall them...note the cam shafts have to be removed for this...
i was lucky the diesel oil worked for me....occasionally i get a small amount of the tapping noise when i start up my car..(note i work off shore 28 days on 28 days off...this means for at least 28 days my omega is just there sleeping) after running for may be 30 min the noise is gone....and is more prominent when i haven`t changed my oil for some time...
drop me a line if this works for you..
Regards
R-vin
R-vin
SeedyV6
« Reply #4 on: 18 August 2010, 15:52:32 »
here goes..
Forgive my stupidity! so what weight diesel oil should i be looking at?
R-vin
  • Trinidad, W.I.
  • Best Regards
« Reply #5 on: 18 August 2010, 16:17:01 »
considering my environment is tropical....a 40 weight oil did it for me....however going too light would be bad for your engine...normallu i use 20 -w-50 oil manufactured in my country...and well the diesel oil also from my country has a slightly sweet/squeaky (as a friend described it) smell due to the detergents used in blending it...
what oil do you use...and what temperatures is your car subjected to overnight / day time when not running?
regards
R-vin
R-vin
SeedyV6
« Reply #6 on: 18 August 2010, 16:31:38 »
10w-40 is in it at the moment. The temperatures are mild here overnight at the moment
Varche
  • middle of Andalucia
    • Golf Estate
« Reply #7 on: 18 August 2010, 16:40:58 »
Interesting suggestion R-vin .
I think it won't be long before  a phalanx of Omega knights will be along saying that this might not be such a good idea. From my point of view technically what you suggest is great but the practice may just be to loosen a whole load of crud that will move around your engine potentially doing harm on the way .
Just my view. lets see what the hydraulic lifter treatment does. :y
R-vin
  • Trinidad, W.I.
  • Best Regards
« Reply #8 on: 18 August 2010, 17:36:19 »
hey Varche,
good to hear from you, about the technique i suggested...
the oil that leaves the lifters goes straight back to the sump, not any where else, and this oil goes thru the filter before going to the rest of the engine...plus the diesel oil literally breaks down all the shit to be found in an engine...except metal cuttings,,,
oil is taken directly from the sump, to the oil pump, then the filter...(lets hope it has not been clogged before, oil flows in by pass mode of the filter and sent shit around the entire engine) this is why oil filters should be cut open after every oil change
the only place to be really worried is if any shit goes to the oil sprayers (if applicable) that spray oil to cool the under side of the pistons...they can be clogged...came across a 200sx with a sr20 turbo engine where i could not even free up these oil sprayers when i rebuilt the motor...
 not a real problem for a normally used engine, but one that is abused..needs this extra cooling...
the time period i suggested for the oil change is from experience working on / rebuilding engines / having to wash up parts and stuff...diesel oil works just as well as automatic transmission fluid to clean up parts..(ever seen how clean inside an automatic transmission is)..but you cannot use ATF in an engine.... :'(
SeedyV6...the 10W40 diesel oil should be ok....its how many heating and cooling cycles in between the oil changes...and ensure that you change your oil filter...even if you dont change your oil....sounds bad but this has been a common practice in Trinidad...and is even taught by the older mechanics...LOL
it is your call...your car...this is what i do with my car and its fine..no metal found in the filters at oil changes (powerful magnet sweeps the entire element to find nothing)..but do not use a hacksaw to cut it open...i started off using a can opener...MAKE SURE AND USE GLOVES....BLOOD  SEEN>>>>NOT GOOD!
let me know what you all think
regards
R-vin
R-vin
SeedyV6
« Reply #9 on: 18 August 2010, 18:13:15 »
Ok, so am home now. pulled up and it sounds worse if anything. sounds on both banks. I might be paranoid here but it sounds like i got noise at the bottom as well.
I'd say the lifter treatment was a fail (unless 12-13 miles isn't enough)
So......old homer is parked on my front. i'm gonna wait for the missus to get home so i can use her car to get to a factors / halfords.
I think at the least i should change the oil?
Maybe buy a cheapo brand semi-synth 10W40 for now. Fire it up try running it for a day or 2 and change it again? (i still have the VX oil and filter ready to go in)
If the noise is worse, does this mean that my engine is being slowly starved of oil? If that is the case and the oilways ARE blocked, then where is the harm in trying R-Vins advice or just using plain old flush?
Not sure what to do next, other than what i can here and now by myself (which is probably change the oil!)
Some advice please.......
TIA
Wes.
SeedyV6
« Reply #10 on: 18 August 2010, 19:47:15 »
Been to halfords. Got some of their own 10W40 and some engine flush. will change the oil and see what happens..... :-/
Abiton
« Reply #11 on: 18 August 2010, 20:25:37 »
That can only help.  :y
Look at the oil that comes out and see whether there are any solid or semi-solid lumps in it.
Do change the oil filter as well.
« Last Edit: 18 August 2010, 20:27:19 by Abiton »
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #12 on: 18 August 2010, 20:33:27 »
I would drop the oil, then check the oil pick up pipe, whilst the oil is out its only about 16 bolts to remove. You will need a sump gasket though and some sealer to use sparingly :y
You will then have piece of mind, plus if the problem is still there you know the pick up pipe is out of the equasion.
Poor oil changes cause all sorts of problems....
Whatever you do though dont phone VX for new lifters :o :o :o unless you have a chair near :D
SeedyV6
« Reply #13 on: 18 August 2010, 21:18:22 »
OK, dropped the oil, but left the filter in as i've only got the one Vx jobbie and halfords didn't have the paper type i need. I didn't use the flush as a consequence. Figured i'd save the filter for the Vx oil change.
The oil that has come out is very black. it looks more like it has been in for a year or more rather than 3 months. Bottom of my wash bowl - no metal - thank god! - but a lot of hard oil spots. Some big and some small.
Fired up and noise is still there (obviously) However am now more sure (i think  ::) ) that the noise is top end and not bottom end. Loudest noise is still on drivers side bank, although there is some noise from passenger bank also.
So, tomorrow........use wifeys car to go to work........lunchtime re-visit mr. Vx and get a sump gasket and GREY sealer. (not the black wes, oh no, not more black.....)
After that.......what are peoples thoughts?
Should i use engine flush before dropping the oil again? (i know this one divides people so am asking)
Should i then take the sump off, clean the pick-up, re-fit and fill with VX oil and filter?
Or do another cheapy brand oil and run it for a couple of days before the above?
Is the car ok to run now? What damage will i do if i do go to work in it?
Oh, one more......paper filter on my motor.....what size is the nut jobby on the filter housing (excuse poor terminology)
Sorry for all the questions all at once!
Thanks again,
Wes.
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #14 on: 18 August 2010, 21:29:36 »
I would be removing the sump whilst the oil has drained out get the pick up pipe sorted first than last.
VX oil is not that dear
11/16 or 24mm
Thanks again,
Wes.
Once you have cleaned the pick up pipe, refitted the sump pan, refill with oil the put in lsome Wynns Lifter Treatment or something similar. :y
Pages: [1] 2 3  All   Go Up
