Author Topic: Central locking keyfob distance  (Read 1751 times)
MrDJ
« on: 24 August 2010, 18:36:25 »
it works fine but even with new batterys I usually have to be stood by the drives window.
Anything I can do thats not expensive?
pembsomega
  • pembrokeshire, wales
Re: Central locking keyfob distance
« Reply #1 on: 24 August 2010, 20:37:30 »
Eat an apple? You can get 4 for a about 75p
Abiton
« Reply #2 on: 24 August 2010, 20:49:30 »
 ;D
I was going to say "Use the key".
But I have some more constructive advice too.
I had trouble a while back with ours; rubbish range, and battery life a fraction of what it should be.
I managed to get hold of a much more recent one on Ebay (datestamped later than the time all Omegas went over to RF remotes - guess it was a new replacement from Vx) for not much.  Trouble is, you either need to program the car's ECU to accept the new code that will be in it, or transplant the memory chip from the old remote into the replacement.
Here's my saga: http://www.omegaowners.com/forum/YaBB.pl?num=1255721218
Agemo
  • Cleethorpes
  • Insignia
« Reply #3 on: 24 August 2010, 21:21:57 »
I suppose you have tried holding the plip under your chin . . .  ::)
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #4 on: 24 August 2010, 21:25:12 »
Hold it against your temple, and press the button, should treble the distance.
I like red cars
Matchless
  • Nottingham
    • A white van
« Reply #5 on: 24 August 2010, 21:34:42 »
No good in Wales...they only have Chapels
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #6 on: 24 August 2010, 21:41:10 »
Didn't know you were a wannabe comedian :D
I like red cars
MrDJ
« Reply #7 on: 25 August 2010, 10:11:02 »
;D
Did you get much better range with the new ebay jobbie?
Mine is the old fob like your original and am used to PCB work so sounds like the way forward if it increases the range :)
Abiton
« Reply #8 on: 25 August 2010, 12:55:51 »
Yeah, range much better.  Still has to be line-of-sight to the receiver obviously, but you can ping ours from a metre or more behind the car through the rear screen.
Just a gamble whether an Ebay one is in better condition.  May be better off asking whether anyone on here has a known good'un from a car they're breaking etc.
Suppose if you can get one, just replacing the output driver chip will sort your own, but I seem to remember failing to find a source for that dude.
smithpa7
« Reply #9 on: 25 August 2010, 13:19:06 »
Can anyone tell me where the receiver is?
Abiton
« Reply #10 on: 25 August 2010, 13:24:06 »
Little black dome hanging down near the rear-view mirror IIRC
« Last Edit: 25 August 2010, 13:24:17 by Abiton »
smithpa7
« Reply #11 on: 25 August 2010, 14:03:36 »
Thanks Abiton :y :y
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« Reply #12 on: 26 August 2010, 00:44:18 »
What difference does it make if it doesn't unlock until you're at the car ?  :-?
You can't get in until you're at the door, so why worry ?
Neither of my Omegas unlock if more than a few feet away. I've not found it a problem in the last 9 years.
My mate can unlock and open the sliding rear side door of his Peugeot from about 100 feet away.
 I've warned him that if he tries that in certain areas the car will be gone by the time he gets to it.   :D
davethediver
  • Blackburn, Lancs.
« Reply #13 on: 26 August 2010, 01:54:38 »
 ;D ;D ;D ;D
P.A. Caron de Beaumarchais
