Author Topic: Facelift foglight upgrade  (Read 1184 times)
johny5
  • Portsmouth, Hampshire
« on: 26 August 2010, 23:09:37 »
Hi just wondered if i wanted to go about installing a pair of genuine foglamps into my GLS, hwat parts would i need? i assume the wiring is there as i have plugs in behind the bumper.
Thanks
Iain
Re: Facelift foglight upgrade
« Reply #1 on: 26 August 2010, 23:26:09 »
Set of lights, interior light switch
Take off front bumper,at the back remove the cover where the fog lights go, bolt in the lights, plug in, re-fit bumper, change interior light switch with one with the front fog switch on it
Job done  :y
« Last Edit: 26 August 2010, 23:27:03 by Iain »
johny5
« Reply #2 on: 26 August 2010, 23:27:34 »
is that it? will the wiring for the switch end be behind the blank?
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
« Reply #3 on: 26 August 2010, 23:27:53 »
It should just be a case of fitting the foglights, foglight switch (may need a complete light switch) and possibly pop a fuse in.
Does your bumper have grills fitted, in place of foglights? Theses SHOULD just pop off and foglights slot in place, if not then you may need a different bumper too...
Brikhead
  • West-Mids.
« Reply #4 on: 26 August 2010, 23:28:52 »
I type too slowly! :y
johny5
« Reply #5 on: 26 August 2010, 23:31:53 »
yeah my bumper has the slatted grills but you can pull out where a fog light would go. So would the bumper still have to be taken off to bolt in the lights or can it be done just removing the grills?
Also would i need to get foglight holders or would they be there already?
thanks
« Last Edit: 26 August 2010, 23:32:20 by jpb1234 »
Iain
« Reply #6 on: 26 August 2010, 23:35:11 »
 ;D
The GLS has 'foglight shaped' grilles to continue the black slats,but if you look closely you will see the vertical gaps,once the bumper is off it will either unclip or unbolt.
Definately need the interior switch,the GLS only has 1 button for the rear fogs under the rotary switch that puts the headlights on
Iain
« Reply #7 on: 26 August 2010, 23:40:32 »
Bumper needs to come off..very easy though 4 bolts at the front of each wheel arch, 2 plastic clips on top next to screen wash bottle and 3 clips underneath at the front, once there all off, pull it slightly to get a slight gap then remove the bits of trim from under the headlights.. unclip the outside temp sensor (middle at bottom) bumper off! :y
Pretty sure the grille parts will be clipped from the rear
They are standard bumpers through the range so should just be bolt on and plug in :y
« Last Edit: 26 August 2010, 23:42:27 by Iain »
