Author Topic: Fault codes not listed?  (Read 1014 times)
MrDJ
« on: 25 August 2010, 12:02:05 »
Removed coolant temp sensor lead - found couldn't get to sensor without a ramp so reconnected and now have these codes.
1-5 Coolant temperature sensor Voltage high
3-4 ??
9-3 ??
1-5 fair enough as I have a new sensor anyway but what are the other 2?
mantagte
  • great yarmouth
    • omega bmw maverick
Re: Fault codes not listed?
« Reply #1 on: 25 August 2010, 12:27:24 »
34 is egr solenoid voltage high
93 is immobiliser control module no signal
MrDJ
« Reply #2 on: 25 August 2010, 12:50:12 »
don't know much about cars but googling seems to point to EGR being same area as CTS so ive prob done something :(
No idea why imob is playing up mind..
Abiton
« Reply #3 on: 25 August 2010, 13:01:41 »
Yeah, connector for EGR very adjacent to where you've been doing battle, and the wiring shares a bit of conduit with the temp sensors' wiring IIRC.
Removing the scuttle may make progress with this job considerably easier, I think. Don't have ours (the missus's) here to have a look I'm afraid.
PS, fill in the Location bit of your profile, someone may be near enough and willing to lend a hand.  :)
PPS 93 may be cam-sensor related according to info in this link: http://www.vauxhallownersnetwork.co.uk/archive/index.php/t-179882.html  :-/
Again, you may have knocked the connector while reaching over the engine (just at the front of the black 'Ecotec' strip)
« Last Edit: 25 August 2010, 13:15:15 by Abiton »
MrDJ
« Reply #4 on: 27 August 2010, 10:50:13 »
Knocked a wire off the EGR when messing with coolant temp sensor.
All codes seem to have cleared once put back on - immob code flagging was odd :)
