Author Topic: urgent assistance required  (Read 1505 times)
rob in gib
  • Plymouth
    • Jaguar S type 3.0
« on: 27 August 2010, 08:40:11 »
first let me say hi to all i have been away at sea on deliveries so have not been on in ages
anyway returned home to find oil in the expansion bottle
drained and flushed the cooling system went on a short run and all went wrong
more oil in coolant radiator blew a hole in the plastic end cap
so i think i should be pulling both heads off
but is there something else i should be checking first like the oil cooler i believe these were fitted to the omega
here to hopeing
cheers
Just chilling in the sun. I wish back in the rain like everybody else
Welung666
Re: urgent assistance required
« Reply #1 on: 27 August 2010, 08:41:33 »
Check the oil cooler first as that is the most likely suspect :y
« Reply #2 on: 27 August 2010, 08:51:30 »
Yep typical oil cooler symptoms ;)
« Reply #3 on: 27 August 2010, 09:01:39 »
3rded leave the heads on.  :y
« Reply #4 on: 27 August 2010, 10:30:33 »
Oil cooler, definate.
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #5 on: 27 August 2010, 13:57:04 »
defo oil cooler :y
« Reply #6 on: 27 August 2010, 15:39:43 »
Hi Rob, welcome 'home' :y. Seems like your bad luck isn't as bad as expected  :y :y
rob in gib
  • Plymouth
    • Jaguar S type 3.0
« Reply #7 on: 27 August 2010, 17:01:22 »
Thanks for the replies people
can anyone point e in the direction of the location of the oil cooler so i can check this out
oh and just to moan my bloody bike broke down today as well not happy :( :(
Gaffers
« Reply #8 on: 27 August 2010, 17:14:01 »
It's in the V between the heads.  You'll have to take off the plenum, inlet manifolds, coolant bridge and the oil cooler pipes to get at it.  It's worth changing the stat too while you're there.  You can change it in a day easy, flushing the coolant will take a while and you have to let the sealant kick overnight before putting the coolant back in.  :y
rob in gib
  • Plymouth
    • Jaguar S type 3.0
« Reply #9 on: 27 August 2010, 17:18:02 »
Thank you so much i have just found a guide in the maintenance section working this weekend so will get stripping next week stand by for updates
thanks again
Kneepad
  • West Scotland
« Reply #10 on: 27 August 2010, 18:39:02 »
Guess what's going to be easiest to fix Hmmmm  ;D ;D
Page created in 0.034 seconds with 16 queries.
