Author Topic: update on my non-progress  (Read 943 times)
erubus
  • blairgowrie
« on: 28 August 2010, 18:39:19 »
Hi there guys.  JUst a quick update on my non-progress.
My 2.0 ecotec runs extremely lumpy at idle, as if it's only running on two cylinders.  Ignition system is fine, virtually everything has been replaced.  I suspected that there was a vacuum leak somewhere as the revs rose when easy start was sprayed at a certain area of the engine.  It was in the general vicinity of the HBV, and there was a hose missing.  so fixed all that, started up with high hopes and still the same.  checked all the pipework for the FTVV and still the same.  There was a large dent in the bottom of the inlet manifold and some suspect loking joins in the casting, also the mating faces were badly scored.  So today i fitted a new inlet manifold.  I couldn't get hold of the same one, but got one off of a vectra that was slightly different.  It has a diaphragm on the side that actuates a valve inside it, but seems to be controlled by the ecu.
i gambled that as my engine management doesn't have the connector for the valve that it would stay in the closed position and present no problem, is this the case?
It took a bit of creative pipework, but got it fitted and started up the engine, again with high hopes.  Not a bit of it though!  still running exactly the same.
I sprayed the last of the easy start into it and the revs went up still.  The only thing that I haven't changed so far is the servo pipe.  I have listened to it through a stethoscope and it doesn't sound like it's leaking, although if i press the brake then rev the engine, the pedal goes down further, so maybe it is that.  It's certainly the only thing that i haven't changed so far.
The engine seems to run pretty much ok at high revs, just when it slows down again it starts to run like shit, and usually just cuts out.
I'm starting to get to the end of my tether now, Don't want to count my chickens but it looks like i will be getting a new job, which will initially involve a considerable drop in wages and i just can't afford to run the landy to work everyday so i need to get this fixed.
anyone in my area got a working xev?
gill
Dom
Re: update on my non-progress
« Reply #1 on: 28 August 2010, 20:00:32 »
Hi - I know that you say that your ignition is fine and that you have replaced nearly everthing. However, I have had my fingers burned over the last few months problem solving a 2.2 with simular syptoms as yours. It turned out, with help from Welung666 and a his computor, that the fault was the coil pack that I had already changed with a used one that had them same fault! See the thread 'Omega 2.2 - running on 3 cylinders! ECU fault?'
Good luck sorting it out!
« Last Edit: 28 August 2010, 20:10:30 by Car2010 »
Abiton
« Reply #2 on: 28 August 2010, 20:47:56 »
Hows about taking the brake servo connection off the manifold and plugging the hole?  If things improve at idle, stationary, you'll have proved that there's a leak in the servo pipework or something attached to it, I think.
Prob best not to drive it like this though.
