Author Topic: oil leak at fromt  (Read 781 times)
Kaycee
  • Doncaster
oil leak at fromt
« on: 29 August 2010, 07:09:08 »
further to the oil leak coming from front of engine under oil switch it as now become certain where its coming from as the leak ad started getting bad again and all round the switch i tried a different washer and some of the gasket stuff you can get the blue stuff i let it go off and looked the following day started it up and loads of oil coming out the boss was cracked oil spewing out i tightened it to correct torque 40 lb/ft but i did av this helicoiled as its allways leaked from here daz says he can do it but its a big job but as got lot of work on so ill have to wait just wanted to say ive seen other threads about this leak here under the switch and gm changed the pump on 2.6 and 3.2s so worth a check to see if anyone else got a crack there
rob
There is a tide in the affairs of man if taken at the flood will lead on to greater things
