Author Topic: Help Req  (Read 3042 times)
Vauxste
  • North Wales
Re: Help Req
« Reply #15 on: 24 August 2010, 19:12:15 »
Hi Mathewst
Starts from cold no probs - problem only arises when up to temp. It did cut out on Tuesday and would not start right away. Ordered a cam sensor from Vauxhall Car Parts online still waiting 6 days later Ho Hum I am sure it will be here tomorrow
Steve
Re: Help Req
« Reply #16 on: 28 August 2010, 09:56:29 »
Nice to meet Steve yesterday...
Code read showed the following
Total number of fault codes: 5
P0100 - Mass Air Flow Sensor Voltage Low
 (02) - Present
P0335 - Incorrect RPM Signal
 (08) - Not present
P0340 - Camshaft Sensor Incorrect Signal
 (08) - Not present
P0351 - Electronic Spark Timing (EST) Line Coil Cylinder 1+4 Voltage High
 (01) - Not present
P0352 - Electronic Spark Timing (EST) Line Coil Cylinder 2+3 Voltage High
 (01) - Not present
Maf came and went as intermittant afterwards, but it left here with no codes showing....
Re: Help Req
« Reply #17 on: 28 August 2010, 09:57:21 »
Idle live data :
"My Naff Code Reader" 090714 - PC based diagnostic tool
Date and time>      27/08/2010. 18:44
Workshop information:
The Omega Man
Selected model>      2000      Omega-B      Engine      X 20 XEV
Control Unit:
Keyword #1: 6B
Keyword #2: 8F
Normal timing parameter set.
VIN: W0L0VBF69Y1031843
vehicleManufacturerECUHardwareNumber 90565947 MC
systemSupplierECUHardwareNumber: 2519A
systemSupplierECUSoftwareNumber: 21g21k49e
systemSupplierECUSoftwareVersionNumber: 0A4E
exhaustRegulationOrTypeApprovalNumber: S98003
systemNameOrEngineType:  X20XEV
RepairShopCodeOrTesterSerialNumber:  Not programmed
ProgrammingDate:  FFFFFFFF
Identifier: 020D
CalibrationDate: 565SD010
CalibrationEquipmentSoftwareNumber: E1C00A00
Measuring blocks information:
Battery Voltage      13.9 V
Immobiliser      Active
Immobiliser Signal      Received
Engine Speed      704 RPM
Fuel Pump Relay      Active 0V
TPS Signal (Throttle Position Sensor)      0.55 V
Mass Air Flow Sensor      0.18 V
Mass Air Flow Sensor      6.35 kg/h
Coolant Temperature      1.23 V
Coolant Temperature      85 °C
Intake Air Temperature      1.42 V
Intake Air Temperature      33 °C
Transmission Coding      Manual Transmission
Park/Neutral Switch      P - N  0V
A/C Information Switch (Air Conditioning)      Inactive 0V
A/C Compressor Switch (Air Conditioning)      Inactive 0V
Knock Control      Disabled
Cyl.1   Knock Retard      0 °CA
Cyl.2   Knock Retard      0 °CA
Cyl.3   Knock Retard      0 °CA
Cyl.4   Knock Retard      0 °CA
Vehicle Speed      0 km/h
Secondary Air Pump Relay      Inactive 12V
EGR Pulse Ratio (Exhaust Gas Recirculation)      0%
Fuel Tank Ventilation Valve      0%
O2 Sensor      4.492 mV
O2 Sensor Loop      Closed
Air/Fuel Ratio      Rich
O2 Integrator      0 Steps
O2-Loop BLM Idle (Block Learn Map)      139
O2-Loop BLM Partial Load (Block Learn Map)      134
Desired Engine Idle Speed      704 RPM
Idle Air Control      10 Steps
IAC Integrator (Idle Air Control)      122 Steps
IAC Adaptation Slope (Idle Air Control)      115 Steps
Torque Control      0%
A/C Relay (Air Conditioning)      Inactive 12V
Telltale (Check Light)      Off 12V
Simulated Idle Position Switch      Active
Simulated Part Position Switch      Inactive
Simulated Full Load Switch      Inactive
Spark Angle before TDC (Top Dead Centre)      5 °CA
Engine Speed Limit      Inactive
Injection Pulse      2.08 ms
Fuel Consumption      1%
Blink Code Request      Inactive 12V
Re: Help Req
« Reply #18 on: 28 August 2010, 09:58:05 »
Revved higher live data :
Date and time>      27/08/2010. 18:46
The Omega Man
Control Unit:
Keyword #1: 6B
Keyword #2: 8F
Identifier: 020D
Immobiliser      Active
Engine Speed      5.056 RPM
TPS Signal (Throttle Position Sensor)      1.29 V
Mass Air Flow Sensor      1.62 V
Mass Air Flow Sensor      59.61 kg/h
Coolant Temperature      1.09 V
Coolant Temperature      92 °C
Intake Air Temperature      1.46 V
Intake Air Temperature      32 °C
EGR Pulse Ratio (Exhaust Gas Recirculation)      55%
Fuel Tank Ventilation Valve      9%
O2 Sensor      4.218 mV
Air/Fuel Ratio      Rich
O2 Integrator      114 Steps
O2-Loop BLM Idle (Block Learn Map)      138
Idle Air Control      87 Steps
IAC Integrator (Idle Air Control)      128 Steps
Torque Control      0%
Simulated Idle Position Switch      Inactive
Simulated Part Position Switch      Active
Spark Angle before TDC (Top Dead Centre)      37 °CA
Injection Pulse      2.39 ms
Fuel Consumption      12%
Re: Help Req
« Reply #19 on: 28 August 2010, 10:00:25 »
I am not familiar with the 2.0 engine....but am not sure the MAF readings look right, which goes hand in hand with the intermittant MAF code...
Car runs very nicely and is smooth and quiet, jumped about a little, prob with aircon load.
The old solar sensor code in the climate ecu, which many facelifts suffer with.
Least the codes are gone now, so any that reveal in the future can be acted upon easier  :y
Vauxste
  • North Wales
Re: Help Req
« Reply #20 on: 28 August 2010, 19:59:50 »
Misfire and poor running is now cured. It was the cam sensor after all.It now has new coil and crank sensor as well. Thanks to Jimbob, he cleared the codes and checked it live. All Ok except for what could be an intermittent MAF fault which does not show up when driving.
Steve :)
P.S Thanks James
Re: Help Req
« Reply #21 on: 29 August 2010, 10:11:22 »
No worries, nice to meet you, ill happily check em again in a few weeks and check nothing surfaces  :y
