Author Topic: car wont start  (Read 1220 times)
dave quinn
car wont start
« on: 30 August 2010, 13:40:40 »
hello i have an omega 22 petrol auto 51 plate i came home the other day stopped the car ,got back in it 2 days later and it woudn,t start ,it would tick over but not fire up,i then noticed the car with a spanner on it flashing car wont start any ideas
Proz
  • Largoward , Fife , Scotland
    • Omega-less now :-/
Re: car wont start
« Reply #1 on: 30 August 2010, 13:42:29 »
IIRC the flashing car/spanner is something to do with the imobiliser  :-/
Proz
Re: car wont start
« Reply #2 on: 30 August 2010, 13:43:22 »
Where are you .... you may be near someone with a code reader willing to help  :y
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
Re: car wont start
« Reply #3 on: 30 August 2010, 13:53:49 »
As said, flashing e.m.l. signifies that the immobilizer has not been disengaged, have you had your key apart recently?
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: car wont start
« Reply #4 on: 30 August 2010, 14:17:27 »
Sounds like your key needs re-programming.
Where abouts are you?
I like red cars
Re: car wont start
« Reply #5 on: 30 August 2010, 18:20:54 »
Did the 'horseshoe section of the key (with the key blade) pull away from the fob when you removed it from the ignition the last time it was running OK? If so, the immobiliser transponder chip has probably fallen out! Remove the said section again & check that the chip is/isn't there. If it isn't, you need to search the interior/exterior of the car very systematically as the chip is very small  :-/l
