Author Topic: recommended grease for storage of mechanical parts  (Read 889 times)
humbucker
  • Cambridgeshire
    • www.irmscherMV6.com
« on: 31 August 2010, 21:54:51 »
hi all
anyone got recommendation(s) regarding the kind of grease you can use for, say, camshafts and other types of mechanical parts while theyre being stored out of an engine? is vaseline good enough for this kind of thing?
PM with your requests.
tidla
  • solihull
Re: recommended grease for storage of mechanical parts
« Reply #1 on: 31 August 2010, 22:20:35 »
new brake discs come in grease paper.at least the dust wont stick.
fergy
  • Hereford
  • 2001 CDX 2.2dti Estate
« Reply #2 on: 31 August 2010, 22:28:41 »
A  generous coat of warmed Waxoil or similar should suffice.  About £20 from most factors. Plough shares were traditionally treated with a lanolin based compound when out of use and generally stored in the open. I understand the stuff is still available but a tad on the expensive side. I can't see why vaseline should not work though.
« Reply #3 on: 01 September 2010, 08:43:20 »
WD40.....spray it well and then wrap them in cling film.
Its the one thing WD40 is quite good at  ;D
