Author Topic: torque settings for hub nuts  (Read 3756 times)
a-ton
  • gloucestershire
« on: 24 August 2010, 15:43:11 »
Does anybody know what the torque settings are for the front hub nuts on 2.6 2001 please?
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: torque settings for hub nuts
« Reply #1 on: 24 August 2010, 15:45:27 »
240nm
I like red cars
a-ton
  • gloucestershire
« Reply #2 on: 24 August 2010, 15:48:34 »
thank you.
« Reply #3 on: 24 August 2010, 16:10:08 »
Isn't it 320nm?
2woody
  • Northumberland
« Reply #4 on: 24 August 2010, 16:12:27 »
I'm sure it's 320 Nm
very, very tight !
« Reply #5 on: 24 August 2010, 16:17:02 »
IIRC its just over my largest torque wrench setting which is 310nm
« Reply #6 on: 24 August 2010, 16:17:49 »
Yep its 320Nm - scaffold pole tight  :y
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #7 on: 24 August 2010, 16:19:52 »
Oooops, 320nm. :-[
I like red cars
« Reply #8 on: 24 August 2010, 17:25:40 »
Just done one of mine not 10 mins ago, and yes 320 nm, but I don't have a torque wrench that big, so how many grunts to 320nm?
I got a feel for the leverage on the old one after backing it off and tightening a fraction at a time with the top half of a 3 ton trolly Jack handle on a large ratchet, best I could do.
Can I expect it to bed in and need a nip, or is it 320 job done? Mark seems to have a method for this if there is play on old ones by nipping the nut up a little, which I did twice on the one I just changed, maybe there is some feel involved.
....and what's Haynes on about with a plastic sleeve in the description?
Feels far better now anyway, knocking gone and smoother. :y
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #9 on: 24 August 2010, 19:08:27 »
You can imagine the needed torque like this: 320 Nm is approximately 32 kilograms on a one meter lever. So, you'll need 64 kilograms on a 50 cm lever and so on... With a regular T-handle of your socket set (which is around 25 cm or so) you can stand on with one foot.
As result, the nut is as tight as one can get it with handtools
« Reply #10 on: 24 August 2010, 19:27:26 »
that can't be right :-/. 32 kg can be picked up with one hand, and placed on the end of a meter long lever isn't going to do much tightening. 320 Nm tight is ball breaking tight ..... the proverbial tighten till you fart - then another quater turn. ;)  ;)
320Nm in 'English' is 236lbft which uses the same method as yours ie 236 lbs on the end of a lever one foot long. That's going to equate to much much more than 36kg on a meter long bar.  :-/  :-/
« Reply #11 on: 24 August 2010, 19:38:55 »
;D ;D :y
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #12 on: 24 August 2010, 19:42:14 »
;D ;D :y
Don't use Jimbob as a torque gauge though, his calibration is out. ;D ;D
TuBy's new whipping boy.
« Reply #13 on: 24 August 2010, 19:58:05 »
One stain or two tight?  ;D
However.. if you do the maths, it really is 36Kg/m ..
236lb/ft would be roughly 78lb/yard, and if we assume a yard is more or less a metre (I know, it isn't quite) then you get 78lb/m.
2.2lb in a Kg, so 78/2.2 = 35.5Kg/m ..
« Reply #14 on: 24 August 2010, 20:53:25 »
 ;D  ;D  ;D  ;D  ;D  ;D
