Author Topic: TD ar35 torque settings  (Read 970 times)
BRIGSPORT
  • Sunny Lancashire
« on: 02 September 2010, 18:12:22 »
What are the torque settings to use when changing bell housings, and also tightening sequence? Thanks.
Kneepad
  • West Scotland
Re: TD ar35 torque settings
« Reply #1 on: 02 September 2010, 19:00:44 »
Torque
3 upper screws for converter housing to engine – 60 Nm / 44 lbf. ft. 2 screws  for starter to engine – 40 Nm / 29.5 lbf. ft.
Cover plate to converter housing (1 screw) – 5 Nm / 3.7 lbf. ft.
Converter to drive plate (3 screws) – 55 Nm / 40.5 lbf. ft. Insert cover cap.
4 lower fastening bolts  to converter housing (M8) – 20 Nm / 15 lbf. ft.
4 lower fastening bolts  to converter housing (M10) – 40 Nm / 29.5 lbf. ft.
1 lower fastening bolt  to converter housing – 60 Nm / 44 lbf. ft.
No tightening sequence given but if you go to diagonally opposing bolt you won't go wrong.   :y
BRIGSPORT
  • Sunny Lancashire
« Reply #2 on: 02 September 2010, 20:13:59 »
Thank you very much. :y
