Author Topic: V6 passenger side exhaust manifold gasket change  (Read 1906 times)
Varche
  • middle of Andalucia
    • Golf Estate
« on: 23 December 2009, 15:18:37 »
I've had a look at http://www.omegaowners.com/forum/YaBB.pl?num=1258711484
and also had a look in the haynes (which says can't be done with the engine in situ).
When MDTM says "move engine over a bit" - is that undoing the passenger side engine mount and jacking it up a bit?
I have a level ramp for whole car with 40cm of clearance to work under which is a plus. A minus is I can't really get a good look at anything. I have bought the genuine GM gasket (10 euros 50). Both cats have been off a million times so no issue there.
Is it safe to plus gas the manifold bolts when warm?
Anything else I need or any tips greatly appreciated?
varche
Re: V6 passenger side exhaust manifold gasket change
« Reply #1 on: 26 December 2009, 15:15:42 »
It CAN be done in situ. It's a pain in the @rse, though.
Remove the engine mount and swing itover.... just don't break any studs!
JasonH
« Reply #2 on: 26 December 2009, 21:46:00 »
My notes:
PASSENGER SIDE EXHAUST MANIFOLD GASKET  REPLACEMENT
Took 2 full days – mainly due to fiddly problems.
On the facelift 2.5 V6 it’s not essential to remove the engine or even to move the engine.
The job goes like this (sorry no pictures just needed to get it done).
Parts
Coolant transfer pipe O-rings x 2
Dipstick tube O-rings x 2 (cost about £3 each retail !)
Coolant
Exhaust downpipe nuts M10 x 2            90570845   approx £1.50 each (have helicoil insert)
Manifold gasket                              24416110            £5.91
Manifold nuts x 7                        11082413            £0.26 each  (get a couple spare)
Manifold studs x 7                        90106924            £0.45 each  (get a couple spare)
Front pipe gasket                        90499289            £4.55 each
Secondary Air Injection gaskets x 2         90467427            £0.40 each
Few M8 nuts (I think, check them on the new studs) to use to lock together to get studs in and studs out
The job
Drain the coolant using red tap at bottom corner of radiator – note that this may not be required. Depends on how lucky you feel just rotating the coolant transfer pipe.
Jack up the passenger side front wheel.
Fit axle stand.
Remove passenger side front wheel (easier to get in and out from under car and allows access to one exhaust stud through hole in wheel arch).
Remove passenger side cat:
Undo the 16mm nuts connecting exhaust manifold to down pipe (long extension required). I’d recommend tapping the ratchet round with a hammer to reduce the chance of shearing the studs on the exhaust manifold.
Separate the cat from the mid box – these bolts will be solid. 13mm head. Grind off protruding thread to help undoing. Lots of penetrating oil. Tap ratchet with hammer to try to prevent shearing. If they do shear it’s not the end of the world. When the cat’s off drill out the bolt and when you put everything back together use a nut and bolt rather than bolting into the tapped part on the cat.
Undo the 13mm support bolt.
Catch the very heavy downpipe / cat.
Penetrating oil on all exhaust heat shield bolts.
4 bolts on top heat shield, one hidden one just about accessible from underneath.
2 bolts for lower heat shield.
Removed using E10 torx socket and 8mm ratchet ring spanner. Quite fiddly.
You might find one or two shear off, although none of mine did.
You can just about drag the top heatshield out of the way down past where the downpipe was fitted.
You do need it out of the way.
Ignition on, disconnect battery –ve
Remove +ve feed from battery (to give a little bit more room)
Lift cover for ECU box slide it up and out, partially lift out loom to engine (to get some extra room to work)
Undo and remove bracket holding PAS reservoir.
Unclip and remove bonnet switch.
Unclip wiring near PAS reservoir from stud on suspension turret.
Undo and remove bracket near dipstick holding earth wire and aircon pipe. You’ll need to unclip the earth wire.
Undo the Secondary Air Injection pipe at the hose end and at the two points where it goes into the exhaust manifold.
I couldn’t get the SAI pipe out so I left it in place and moved it around when required.
Undo the b*stard bolt holding the engine lifting bracket, coolant transfer pipe and dipstick in place. Make a note of where the spacer goes.
Rotate the lifting bracket and remove it. It has a L at the bottom which is why is doesn’t just slide out.
You need to rotate the coolant transfer pipe to allow the dipstick to be released. If you think the O-rings will keep their seal then there is no need to remove the coolant transfer pipe but really you should remove it and replace the O-rings once you’ve disturbed it.
Now you need to get the dipstick out. This is hard and took me a lot of time. At this point it “just pulls out”. I broke a nylon 500kg rope trying to “pull it out”. You need to pull in the right direction – roughly next to where the PAS reservoir sits is about right. Rotate the dipstick to loosen it, wiggle and pull. Pull, pull, pull. Mine came out mm by mm. I tried rope round the bracket on to a long bar that rested on a block of wood on the suspension turret. Got huge amount of leverage, which may have loosened it.
You have to get the dipstick out to gain access to one stud. I tried to work around it but you’ll never get the stud back in.
Undo the manifold studs. You’ll need a selection of ratchet extensions to get on to the studs. One can be accessed through a hole in the wheel arch.
Post 98 models should have the non-seize manifold nuts fitted
Make sure you get the most sturdy ratchet you can on and get the socket on square. The nuts are copper and easily round off. With a solid tug they’ll all undo. Generally the stud comes out of the block – which is very helpful.
I used ½” drive where possible to undo.
3/8” drive where I had to.
But for refitting a ¼” drive got you a long way.
If one shears the best option may be to live without it. On mine the rear most stud had sheared all on its own. Luckily there was a fair bit of stud left and it even had thread on it. To get it out I had to get a nut welded on. The heat from the welding probably helped to – but it was still very tight.
On the facelift V6 (at least) the studs seem to generally come out whole. The others did and so did they when I did the driver’s side.
Clean the head face well and check the manifold for cracks (just in case) then clean manifold face and check it’s flat.
Then put it all back together.
You may have to judge the torque in some cases (can’t get the torque wrench in). I found nice and tight with a ¼” drive was about right.
You might drop the odd stud (hence the spares) sometimes they disappear.
To be continued...
JasonH
« Reply #3 on: 26 December 2009, 21:46:25 »
When you put the new studs in they generally do up into the block before the new nut starts working its way down the thread. The new nuts are supplied slightly swashed. If it goes wrong, wind the nut back and put a second (spare) M8 nut on the exposed thread and wind the top nut in so the nuts lock together. A quick undo on the outer nut usually recovers it – although one is still there!
You might want to use a few washers on the heat shield to hold it in place where the bolt holes have enlarged.
Dipstick tube with new O-rings and plenty of grease pushes in a lot easier than getting it out. Clean hands and a firm wiggle and press down does the trick. Get the bracket back in the right place then put the coolant transfer pipe back to right position.
Wiggle the lifting bracket roughly into place but leave it a 90 degrees so you can see what you’re doing. Now ensure the holes are all lined up with a small screw driver.
The b*start bolt holding the engine lifting bracket, dipstick and coolant transfer pipe is a bugger to get in. My tip would be to get something large and blunt like a ½” extension bar, use that to bounce down on the PAS pipe as you slot the nut past the pipe. A 10mm ratchet ring spanner then slotted in allows you to turn the (torx) head whilst you try to line it up with a finger.
Then basically put everything back carefully (ran out of time to finish the guide…)
amba
  • Medway towns
    • German V6
« Reply #4 on: 02 September 2010, 20:58:08 »
Can anybody confirm if the excellent guide provided by JasonH would be applicable to a mini facelift as assume some parts would differ slightly.
The moving of the engine from its mounts ??
Can anybody again shed abit more light on what actually is required to do this.Just undo mounting points or totally remove which I then assume would require support from below with jack and some strong wooden planks.
Varche
    • Golf Estate
« Reply #5 on: 02 September 2010, 22:43:14 »
I managed mine (mini facelift) OK. I loosened the engine mounts and wedged a half inch bar in between to in effect raise the engine on one side.
I just used a new gasket and followed the rest of the guide as best I could. All very fiddly but would be faster if I ever did it a second time. I would recommend getting the parts particularly the coolant transfer pipe and seals. It was sort of hobsons choice for me as Opel dealers are ???!!! here
