Author Topic: Drop links  (Read 1618 times)
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
Drop links
« on: 03 September 2010, 09:57:26 »
I'm told mine need replacing (clunking over bumps)
Is there a recommended brand that should be used & what cost should I expect?
Any advice on fitting?
Sixstring
  • Lydney, Gloucestershire
Re: Drop links
« Reply #1 on: 03 September 2010, 10:00:39 »
Piece of cake mate, 30 mins max per side. if you don't feel confident, drop over to me and I'll do them for you Gratis.
Otherwise, its 2x 17mm (or could be 18mm......) spanners, a wheelbrace, axle stands and trolley jack and lastly a pair of molegrips.
Simples!!
Jinglemaster2
Re: Drop links
« Reply #2 on: 03 September 2010, 10:23:47 »
And a large blow torch. And a box of band aids.
Any brand is fine. FAI are about £8 each.
« Last Edit: 03 September 2010, 10:23:56 by Jinglemaster2 »
Sixstring
Re: Drop links
« Reply #3 on: 03 September 2010, 11:22:59 »
......and a box of Band Aids..................
PMSL.............when I did mine, I used 3 of them on my fingers!!
« Last Edit: 03 September 2010, 11:24:47 by Sixstring »
