Author Topic: Failed MOT  (Read 2795 times)
downsmen
  • Kent
    • 2.5 V6 Elite Estate
Failed MOT
« on: 03 September 2010, 16:47:41 »
Not Happy :( :(
Just got back from MOT and it has failed on Both Headlights being to High and the OffSide beam Pointing the wrong way.
Any one got any ideas how i can adjust this so it will pass?
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
Re: Failed MOT
« Reply #1 on: 03 September 2010, 16:52:57 »
level sensor on the front nearside wishbone popped out?
downsmen
  • Kent
Re: Failed MOT
« Reply #2 on: 03 September 2010, 16:59:23 »
It did a while back :'( but i put it back in, but obviously in the wrong position.
What should i do to correct this?
Re: Failed MOT
« Reply #3 on: 03 September 2010, 17:09:16 »
I would say its more than likely to be the headlight adjusters broken.
Re: Failed MOT
« Reply #4 on: 03 September 2010, 17:09:36 »
Wheel off, good squirt of Plusgas on each sensor leg pivot ball, & a couple of cable ties to hold the sensor head onto the main body  :y
downsmen
  • Kent
Re: Failed MOT
« Reply #5 on: 03 September 2010, 17:17:05 »
How do you see if the adjusters are broken?
Also what about the beam pointing the wrong way, is this changeable to drive abroad
Welung666
Re: Failed MOT
« Reply #6 on: 03 September 2010, 17:19:00 »
Pop off one of the rubber bulb covers and try moving the innards with your fingers. If they move more a millimetre or two then the adjusters are broken. Have a look in the parts section for a sticky at the top for replacements :y
tidla
  • solihull
Re: Failed MOT
« Reply #7 on: 03 September 2010, 17:20:08 »
if you take off the headlight rubber cover, grab the bulb holder, gentle pull and push will tell you, chances are the adjuster has fell to bits.
replacement bits in the off shop.
(too slow)
dont forget to check the beam setting lever is in the correct position.
« Last Edit: 03 September 2010, 17:21:54 by tapper888 »
downsmen
  • Kent
Re: Failed MOT
« Reply #8 on: 03 September 2010, 17:22:09 »
Okay will go and try that now :y
Re: Failed MOT
« Reply #9 on: 03 September 2010, 17:23:58 »
Just be careful, its quite high voltage at the back of there ;)
downsmen
  • Kent
Re: Failed MOT
« Reply #10 on: 03 September 2010, 17:28:48 »
I can move the bit with the bulbs in back and forward about 1cm and up and down a bit as well i guess there knackered  :'( :'( :'(
Gaffers
Re: Failed MOT
« Reply #11 on: 03 September 2010, 17:31:32 »
Easy and relatively cheap fix. Just think if you had to replace the headlamps  :y
Re: Failed MOT
« Reply #12 on: 03 September 2010, 17:32:06 »
Its a common one, replace the crap plastic adjusters with the alloy one available to the forum members ;)
downsmen
  • Kent
Re: Failed MOT
« Reply #13 on: 03 September 2010, 17:35:22 »
Okay where do i get these from?
alank46
  • South Devon
    • 3L Elite Estate 1996
Re: Failed MOT
« Reply #14 on: 03 September 2010, 17:40:32 »
Hi
Have a look at Welung's reply above.
Alan
