Author Topic: need a wee bit help  (Read 1325 times)
brian36
  • Milton Keynes
  • 2.6 mv6
need a wee bit help
« on: 04 September 2010, 21:22:57 »
good day to all,
excuse my lack of mechanical knowledge but have a wee and annoying problem with my omega b elite.
when i go over a pothole or large matchstick i get a real thud from front ,the springs seem fine as do shockers  i did the simple push down on bonnet thing, strange thing is front goes over with a thud but back goes no probs could this be wishbones? would appreciate your views and best place to get the parts, many thanks :)
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: need a wee bit help
« Reply #1 on: 04 September 2010, 21:24:35 »
Check all suspension components.
Wishbones
Drop Links
Track Rod's (and Track Rod Ends)
Steering Connection
Steering Idler
You'll probably find play in one or more of these components.
« Reply #2 on: 04 September 2010, 21:25:41 »
Droplinks mate. Easy enough to change 15mins each side, price varies from £8-15 each
« Reply #3 on: 04 September 2010, 21:28:16 »
Droplinks just to left of centre in this pic. Long black arm with balljoint either end http://www.omegaowners.com/forum/YaBB.pl?num=1219190177
dbr
  • north east.
    • 1997. 2.5CD petrol
« Reply #4 on: 04 September 2010, 21:29:20 »
good day to all,
Could be, also  look for strange tyre wear. Mine did the inside edge.   Got mine from Andrew Page
brian36
  • Milton Keynes
  • 2.6 mv6
« Reply #5 on: 04 September 2010, 21:32:55 »
thanks to all will get track rod ends a nd drop links etc checked while on can you clarify is the company mentioned by many vauxparts www.vauxcentre.co.uk ? thanks
tidla
  • solihull
« Reply #6 on: 04 September 2010, 21:37:11 »
drop link check. just to add in case no ones mentioned it. jack on the cross beam/centre so both wheels are off the ground (level in the air) or on the ground if using a pit/ramps
brian36
  • Milton Keynes
  • 2.6 mv6
« Reply #7 on: 04 September 2010, 21:44:10 »
ok thanks will check tomorrow cheers
