Author Topic: water problem  (Read 1113 times)
paul_hancox
water problem
« on: 05 September 2010, 09:36:21 »
hello . i got a bit of a problem with the water in the exspansion bottle.when i fill it to the top marker . could drive 5 minutes down the road and check it. it would be empty again any suggestions on were it is going . thanks
Jinglemaster2
Re: water problem
« Reply #1 on: 05 September 2010, 09:55:13 »
It is obviously losing water.
Look for obvious leaks/drips etc. Common leak place is the Heater Bypas Valve. It is located just under the scuttle at the back of the engine. Very common to leak.
The water has to go somewhere, so it is either leaking externally or internally. If internally you woud be looking at possible head problem/gasket.
paul_hancox
Re: water problem
« Reply #2 on: 05 September 2010, 10:02:03 »
well i did look for the obvious leeks but there is no dripping . so i mate told me to look on the oil cap to see if there is any white mayo bits on it . bit i checked o and it was just black . so that was ok
i will have to look at the back of the engine to see if is leeking .
zvi
  • IL
Re: water problem
« Reply #3 on: 05 September 2010, 10:17:13 »
Check also if water comes out from the exhaust
