Author Topic: Car losing a LOT of coolant!  (Read 4083 times)
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: Car losing a LOT of coolant!
« Reply #15 on: 02 September 2010, 13:51:45 »
just noticed that my mig has lost a litre or so of water this last week which is unusual as I have never had to top it up before,turned the heater to hot and water pi$$ing down the back of the engine although strangely does not leak when temp set to normal so looks like I need to empty the swearbox in readiness :-X :-*
other rides
SMD
  • London
    • :( nowt
« Reply #16 on: 02 September 2010, 21:12:45 »
Thanks for the comments and the link. I take it you dont need to access the underside of the car..?
Where is the drain off for the coolant? (or can it be done without draining?)
SMD
  • London
    • :( nowt
« Reply #17 on: 04 September 2010, 17:03:53 »
Well I gave it a go and I gave up after a couple of hours! Its impossible to get to with the tools that I have (waterpump pliers). I moved the tubes and hoses I could out of the way and removed the breather tubes (?) although I couldn't get the black support plate off (don't have torx bits).
I didn't even get one hose off! The clip on the hose to the passenger side which is impossible to get to anyway, is facing downwards.
Any moral support and guidance would be appreciated.
« Last Edit: 04 September 2010, 17:06:22 by SMD »
henryd
  • west cornwall
« Reply #18 on: 04 September 2010, 17:10:16 »
It is a bloody awkward thing to change, I did mine today and I removed the plenum but I did not touch the scuttle panel, I have set of remote hose clip pliers that made the job a little easier. If you can borrow a set of these it will help
other rides
SMD
  • London
    • :( nowt
« Reply #19 on: 04 September 2010, 17:16:02 »
What part is the plenum? Why didnt you remove the scuttle?
I dont know anyone with remote hose clip pliers, wanna lend me yours?   ;D
henryd
  • west cornwall
« Reply #20 on: 04 September 2010, 17:23:14 »
The big silver bit in the centre of the v of the engine, I just thought it was easier to remove that bit instead of the scuttle, gave me a chance to clean the breathers out at the same time :y
Edit I would gladly lend you my pliers if you were closer,mine are made by snap on and were quite expensive but there are cheaper one available
« Last Edit: 04 September 2010, 17:25:56 by henryd123 »
other rides
geoffr70
  • Sunderland
  • Boobies
    • F/L 3.0 Elite, 3.0 MV6
« Reply #21 on: 04 September 2010, 21:20:49 »
I changed mine last week whilst doing other work, so had the plenum and other bits off already. I would say to take the scuttle off, it takes 2 mins and is much quicker and easier than plenum etc.
Use a flathead screwdriver to prise caps off end of wiper arm fixing. Use 13mm socket undo nut on wiper arm. Spray a little penetrating spray on thread, it will be a little stiff. Ease your wipers off, best to keep threads parallel so comes off easier. I find it easier to do it with bonnet up. Undo fixings on scuttle, torx 25 or 27 IIRC. Move to one side. You should have access to your HBV. I used mole grips because they lock, long nose pliers and normal pliers to get hose clips off. Remember which order pipes connect (take pic on your phone). Tale vacuum pipe off, and coolant pipes. Fit new one. There is no need to drain coolant. But make sure it's not hot when you do it so you don't burn yourself.
I was doing mine as I say whilst doing other work, but individually I'd have thought it'd take no longer than half an hour.
If you can't get a purchase on the clips, I would try lubricating them and gradually moving them round so you can. Either with pliers or rotating HBV, or whichever you can.
In my (limited) experience, most jobs are awkward and fiddly, but straightforward. HTH
TC and BnQ Trade holder.
SMD
  • London
    • :( nowt
« Reply #22 on: 04 September 2010, 21:38:37 »
Yeah I took the scuttle off and drained the coolant because I wanted to flush the system at the same time. The scuttle and the wipers are sitting in the boot so I hope it doesnt rain.
I think I will buy a pair of long nose pliers and some torx bits tomorrow and give it another go.
Kneepad
  • West Scotland
« Reply #23 on: 04 September 2010, 22:09:53 »
I topped it up yesterday when I got the warning on the computer and twice today (roughly 2-3 litres total). As I drive up to my parking slot I can see a long trail of coolant left behind on the road.  :-[
Whats the cause and whats the fix?
Cheers
I wonder if SMD has just overfilled it and the water was coming out of the expanson tank breather pipe.   ::)
geoffr70
  • Sunderland
  • Boobies
« Reply #24 on: 04 September 2010, 22:30:35 »
You can get your hand in under the HBV to check for leaks without removing anything. It's a little tight but possible. Take your watch off! When mine went it wasn't gradual, one morning i'd lost a load of coolant and that was that. Don't put your hand in when hot!
SMD
  • London
    • :( nowt
« Reply #25 on: 04 September 2010, 23:09:50 »
I hope that is the case TBH but I remember it dripping after every journey before this incident, when I used to regularly look underneath the car for oil leaks. Just ignored it.  :-[
As for overfilling, how would this happen? I always top it up to the mark on the expansion tank.
« Last Edit: 04 September 2010, 23:10:05 by SMD »
Kneepad
  • West Scotland
« Reply #26 on: 04 September 2010, 23:33:09 »
Then ignore my comment. It was just a thought.  :-X
Welung666
« Reply #27 on: 04 September 2010, 23:36:27 »
There isn't an overflow pipe! The coolant bottle is fitted with a pressure cap.
Kneepad
  • West Scotland
« Reply #28 on: 05 September 2010, 00:12:25 »
Foot has now been removed from mouth.  :y
SMD
  • London
    • :( nowt
« Reply #29 on: 05 September 2010, 18:53:00 »
It was a pain in the arse but it got done in the end. Removing the support plate helped lots and no plasters required. It made sense to flush out the cooling system at the same time and put VX 5 year stuff in so thats another job out the way.
Cheers guys  :y
« Last Edit: 05 September 2010, 18:54:37 by SMD »
Page created in 0.025 seconds with 20 queries.
