Pages: 1 2 [3]  All   Go Down
Author Topic: which one?  (Read 5360 times)
C2raig
Re: which one?
« Reply #30 on: 06 September 2010, 00:59:17 »
I'm just thinking I'd prefer a facelift to an early model. I reckon it would cut more of a dash in my office car park, the later cars seem to have more presence.
Was the facelift fitted with the 3.0 and a slushbox? Must be a slushbox.
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: which one?
« Reply #31 on: 06 September 2010, 01:05:05 »
You'll struggle to find an Elite, be it Pre Facelift or Facelift with a Manual Tranny.
They (nearly) all have the lazybox you demand  :y
EDIT:  The Facelift model has a lovely arse, but the front looks like it needs a slap. IMO, obviously.
« Last Edit: 06 September 2010, 01:06:25 by Broomies_Mate »
C2raig
Re: which one?
« Reply #32 on: 06 September 2010, 01:14:01 »
For ages I preferred the pre facelift syling, and either were always going to outdo the Scorpio on looks, but of lat I much prefer the facelift.
I've had my fill of clutch pedals, as I'm sure you can appreciate, doing this many miles makes changing gear a bloody pain.
Also, what's the consensus on estates? Mostly hammered? I don't need an estate but if there's no major difference I'll have one.
davethediver
  • Blackburn, Lancs.
Re: which one?
« Reply #33 on: 06 September 2010, 02:11:58 »
Have a lookie here http://www.omegaowners.com/forum/YaBB.pl?num=1266867411
HTH maybe also worth a look at a 2.5TD with a chipped boxe of course ;D ;D :y
P.A. Caron de Beaumarchais
lightfj
  • Liverpool
Re: which one?
« Reply #34 on: 06 September 2010, 09:39:20 »
I had a W reg 2.6 Elite on LPG some years ago. It was very reliable on gas - it developed other electrical problems due to seat heted elements intermittently failing . It went to France and back from Liverpool umpteen times and was excellent -just make sure gas installation is proper and certificated.
Good luck in your quest.
Agemo
  • Cleethorpes
  • Insignia
Re: which one?
« Reply #35 on: 06 September 2010, 09:44:21 »
the 2.5 v6 cd auto is the one to have.it takes about 100-120 quid to fill the tank.the only one problem ive had with mine is the rocker gaskets
:o
« Last Edit: 06 September 2010, 09:45:49 by Agemo »
C2raig
Re: which one?
« Reply #36 on: 06 September 2010, 10:01:33 »
Because of the Chunnel I'll be avoiding gas. The 2.6 Elite sounds good, wasn't aware that they did a 2.6 Elite.
Martin_1962
Re: which one?
« Reply #37 on: 06 September 2010, 10:04:33 »
i dont own one but the 2.6 s seem to suffer from valve stem seal failure making them use oil on start up from what i have read on here?
Mine doesn't (any more)
C2raig
Re: which one?
« Reply #38 on: 06 September 2010, 10:37:20 »
Its about 600 miles from my place in the UK to my place in France. Currently costs me around £80 in my C2, so I'd expect an Omega to do it for around £120 in a V6 Omega. That'd be perfectly acceptable and still leaves space in my expenses for flooring it.
joshwyatt
  • Oxford
Re: which one?
« Reply #39 on: 06 September 2010, 11:17:40 »
I created a quick guide to the facelift's here with some basic engine and trim info;
It only deals with the DBW engines, so the 2.2, DTI, 2.6 and 3.2
C2raig
Re: which one?
« Reply #40 on: 06 September 2010, 11:26:24 »
Very helpful, thanks.
Pages: 1 2 [3]  All   Go Up
