Author Topic: MAF removal - Rich or Lean ???  (Read 1505 times)
24_Valve
  • Greater London
« on: 05 September 2010, 02:07:19 »
On the 2.5 petrol V6 would removal of the MAF sensor cause the engine to run more rich or more lean? still tweaking the mig to try and get the mixture right... fast running out of options  :-/
Previous: 1996 Omega 2.5i V6 Manual Estate. Pearlescent, Polar Sea Blue. Walnut Trim. A/C & E/S/R. ABS & TC. Heated Seats. 16" Face Lift Alloy's. 225/55 Kuhmo Ecsta KH11 Tyres. NGK BKR5EK Plugs - All Six !
24_Valve
  • Greater London
Re: MAF removal - Rich or Lean ???
« Reply #1 on: 06 September 2010, 00:41:20 »
anyone know?  :-?
« Reply #2 on: 06 September 2010, 01:24:52 »
Thought every thing was basically controlled by the ECU, has something gone wrong that you suspect the MAF
24_Valve
  • Greater London
« Reply #3 on: 06 September 2010, 01:49:09 »
think maf is ok but like you say mixture is controlled by ecu... I'm running lean & know that removing maf changes the ecu parameters for mixture, just can't remember whether it makes mixture more rich or more lean  :y
« Reply #4 on: 06 September 2010, 10:56:37 »
No way of telling, it will be a default map
zvi
  • IL
« Reply #5 on: 06 September 2010, 11:28:59 »
It's a good time to do consumption test and publish the result
