Author Topic: Engine temp on a 2.2  (Read 1777 times)
« on: 05 September 2010, 21:38:22 »
What should this be running at,? gauge reads only a little above 80 on a run, rising a little in town. Outside air temp was 20
I looked in the FAQ and for a V6 this seems to be about right, is this the same for a 2.2?
Water is red, and looks clear and is at the correct level.. :)
Can you tell I nave started using the new Omega now, fresh out the bodyshop... :y :y
Iain
Re: Engine temp on a 2.2
« Reply #1 on: 05 September 2010, 22:04:51 »
Sounds about the same as mine Vamps  :y
Proz
  • Largoward , Fife , Scotland
    • Omega-less now :-/
« Reply #2 on: 05 September 2010, 22:06:50 »
Mine sits about 85 ..... sounds about right to me  :y
« Reply #3 on: 05 September 2010, 22:11:54 »
Thanks Guy's, if it's normal then fine....... :y :y
tidla
  • solihull
« Reply #4 on: 05 September 2010, 22:13:42 »
should tell the doc.
Iain
« Reply #5 on: 05 September 2010, 22:15:07 »
Vamps,i dont know if the V6's are the same but dont be too alarmed if the gauge suddenly goes to Red and the light comes on... pull in switch car off... restart... it will return to normal
Mine does this now and then,seems to be a thing on them, just the sensor i believe
Just thought i'd say it case it happens and it panics ya :)
« Reply #6 on: 05 September 2010, 22:16:43 »
Normal operating range is 83-88
davethediver
  • Blackburn, Lancs.
« Reply #7 on: 05 September 2010, 22:29:39 »
  :o :o
That would scare the s##t out of me mine has gone a little above 90 before now but for the most part it sits at 80-85 half way on the guage :y
P.A. Caron de Beaumarchais
Iain
« Reply #8 on: 05 September 2010, 22:37:30 »
  :o :o
The 1st time mine did it i stood on the brakes and turned the key as soon as it got below 10mph! ;D
Lifted the bonnet and all was NOT overheating, switched it on again and all was back to normal  :-?
I swear i could almost hear the car sniggering!!
davethediver
  • Blackburn, Lancs.
« Reply #9 on: 05 September 2010, 22:52:53 »
  :o :o
Wouldn't be an omega if it didn't wind you up ;D ;D
Iain
« Reply #10 on: 05 September 2010, 22:57:18 »
It takes the piss out of me regularly,i'm convinced of it!  ;D ;D ;D ;D ;D
« Reply #11 on: 05 September 2010, 23:17:41 »
Omega owner, Omega forum poster, one and the same really....... :D :D :D
Iain
« Reply #12 on: 05 September 2010, 23:19:12 »
 ;D ;D
mathewst
  • Split, Croatia
    • v40
« Reply #13 on: 06 September 2010, 09:29:17 »
Actually guys this doesn't sound normal.
On open road it can sit around 85 if you drive easily
But no way it will stay in town traffic.
Sounds like the thermostat is stuck open all the time
Iain
« Reply #14 on: 06 September 2010, 20:14:25 »
Thermostat cant be jammed open if the gauge is going up and down
