Author Topic: No Demist! Servo?  (Read 1275 times)
osealy
  • dublin
No Demist! Servo?
« on: 06 September 2010, 22:30:18 »
No real demist! I guess an arm has fallen off a servo, which side of tunnel is this on? or other ideas?
Re: No Demist! Servo?
« Reply #1 on: 06 September 2010, 23:18:26 »
Is it a broken pipe, it was on our old estate, after being in VX for a cam belt change, pipe not secured properly and melted on the exhaust manifold.. ::)
tutts
  • hull
« Reply #2 on: 07 September 2010, 07:47:09 »
I am having the same problems i found a loose vacuum pipe under the bonnet near the heater matrix pipes on the bulkhead bu still not working,i will be looking for the heater box flap actuator at weekend i will keep you posted.Take a look at my other post on vac pipes. :-[
osealy
  • dublin
« Reply #3 on: 07 September 2010, 09:32:24 »
This car has climate, I think all the flaps are operated by servomotors whose arms pop off, they are awkward to get at & I don't want to start on the wrong side.
« Reply #4 on: 07 September 2010, 10:16:04 »
Nope, only the temp blend flap is servo controled, all the direction flaps are vac based and hence you need to check your vac hoses etc  :y
osealy
  • dublin
« Reply #5 on: 07 September 2010, 13:07:10 »
Thanks for that. On my previous car it was the temp blend arm that popped off! But I thought I saw at least one other servo?
« Reply #6 on: 07 September 2010, 13:37:03 »
Correct there is....for the passenger side temp blend  :y
