MOT Emissions FAIL - Help!
Started by 24_Valve, 18 August 2010, 20:28:29
24_Valve
took the mig for its MOT today and got failed on emissions... the car past the emissioins test at the same garage last year... got 10days to put it right but the question is.. how?
the readings are:
2nd fast idle test:
CO limit 0.3 - actual value 0.51 FAIL
HC limit 200ppm - actual value 145 PASS
Lambda limit 1.03 - actual value 1.05 FAIL
Bosch ESA v 2.35 uk
I also have a centre exhaust leak - don't know if it's relevant?
any idea's welcome  :y
Previous: 1996 Omega 2.5i V6 Manual Estate. Pearlescent, Polar Sea Blue. Walnut Trim. A/C & E/S/R. ABS & TC. Heated Seats. 16" Face Lift Alloy's. 225/55 Kuhmo Ecsta KH11 Tyres. NGK BKR5EK Plugs - All Six !
Bent valve
Put some new plugs and a new air filter in and give it a
good screwing down the motorway :y
Gaffers
The leak will throw off the emmissions, guaranteed.
24_Valve
QuotePosted by: Bent Valve Today at 20:32
new plugs fitted about 6 months ago, air filter about 2yrs.. ?
Exhaust leak will probably make it read lean - which it does (lambda 1.05 is lean of stoic)
And the car is, in fact, running rich (elevated CO & HC)..
Get the exhaust leak fixed, change the air filter, reset the ECU (I'm assuming the Omega stores long & short term fuel trims like most cars), clean the MAF if appropriate, get it nice and warm and take it for a nice long drive, then take it back to the MOT station.
But get the exhaust leak fixed first.
markfree
QuoteExhaust leak will probably make it read lean - which it does (lambda 1.05 is lean of stoic)
If all that fails try a can of cataclean :y
and make sure the shuv the sensor all the way up the exhaust . . . . . .  ::)
24_Valve
thanks for the advice - will get leak fixed & replace air filter (reset ecu etc..) and maybe buy some cataclean? does it work better than fuel additives such as redex etc..? also would valve lift treatment help?
3.2 CHARLIE
Quotetook the mig for its MOT today and got failed on emissions... the car past the emissioins test at the same garage last year... got 10days to put it right but the question is.. how?
the readings are:
2nd fast idle test:
Bosch ESA v 2.35 uk
Scrap-time !!! Sorry !! :D :D :D ;D ;D
Quotethanks for the advice - will get leak fixed & replace air filter (reset ecu etc..) and maybe buy some cataclean? does it work better than fuel additives such as redex etc..? also would valve lift treatment help?
As I understand it, cataclean and redex are designed for different jobs - one is supposed to 'restore' the CAT, Redex is designed to clean & restore the fuelling system on the car..
Can't hurt to try a can of both, mind!
Valve lifter treatment won't do anything for emissions, though, it's just good for treating sticky (tappy) hydraulic lifters (if you're lucky)
the readings are:
2nd fast idle test:
Bosch ESA v 2.35 uk
Thats a clue....whats the engine temp and do you have any codes stored
Road Hog Mad
Maybe its just time for car heaven.
How many miles has it done?
Surely engines conk out at some point despite being well maintained.
QuoteMaybe its just time for car heaven.
Lol, useful...........not  ;D
Road Hog Mad
:P
toxic34
My car passed the emmissions with one of the center exhausts snapped but failed because there was too much escape of the exhaust gases as well as other stuff. Just been stung for 450 notes.  :'(
