Author Topic: brake fluid change  (Read 2298 times)
john6177
  • Near Manchester
brake fluid change
« on: 10 September 2010, 21:26:17 »
Hi,
am going to do a bfc. using vx dot 4. I will be using a power bleeder not 2 person (manual). my question is do i need to follow the wheel sequence in the maint section or can i just do any wheel in any order. :-/ :-/
any help or direction much appreciated
thanks
steve2.5cd
  • Blackburn, Lancs
Re: brake fluid change
« Reply #1 on: 10 September 2010, 21:38:11 »
yes it is better if you follow the wheel sequence  ;)
tidla
  • solihull
« Reply #2 on: 10 September 2010, 21:41:46 »
as a general rule, do the wheel furthest from the master working closer..
    • 530D M Sport, 330i Coupe
« Reply #3 on: 10 September 2010, 21:51:18 »
Yep, i'd follow the guide.
The brake circuit is diagonally split so best to complete a circuit at a time.
john6177
  • Near Manchester
« Reply #4 on: 10 September 2010, 22:06:37 »
so
Rear Passenger
Front Drivers
Rear Drivers
Front Passenger
even with power bleeder
thanks
  • Auckland
    • Mazda MPV
« Reply #5 on: 10 September 2010, 22:13:07 »
I'm not sure if a simple flush will get the old fluid out of the ABS pump and valve block  :-/
I think I read somewhere that Tech 2 is required to energise the ABS pump to pump the old fluid out.
hotel21
  • The Kingdom of Fife
« Reply #6 on: 10 September 2010, 22:17:22 »
If you excercise the ABS pump with a T2 whilst bleeding you certainly clear out the ABS unit at the same time.
I remember M_DTM having to do that at the Lakes meet when Mick Dundee lost his rear pads on his vented rear calipers/non vented rear discs escapade when the pistons popped out....   :o
« Last Edit: 10 September 2010, 22:17:52 by hotel21 »
« Reply #7 on: 10 September 2010, 22:19:56 »
Only really need to energise the ABS pump if you get air bubbles trapped in it, which is where I find the easi-bleed devices to be good (as long as you keep an eye on the reservoir) as they keep a positive constant pressure on the system.
« Reply #8 on: 10 September 2010, 22:23:23 »
The second York meet IIRC  ;)
john6177
  • Near Manchester
« Reply #9 on: 10 September 2010, 23:02:27 »
i dont have tech 2. Oh the capri is so much easier
« Last Edit: 10 September 2010, 23:15:49 by john6177 »
tidla
  • solihull
« Reply #10 on: 10 September 2010, 23:03:57 »
not many do.. just bleed the brakes. :y
  • Auckland
    • Mazda MPV
« Reply #11 on: 11 September 2010, 10:00:56 »
Sorry, didn't mean to suggest it wasn't worth doing. Just pointing out that some of the old fluid might remain in the circuit.
