Author Topic: will not start  (Read 977 times)
leedsleedsleeds
will not start
« on: 11 September 2010, 10:12:52 »
diesel car wont start,fired at first but stalled and will not have it since.been told to bleed/crack the injectors will turning over engine,sorry for being derr brain but is this undoing pipes leading into top off engine.  thanks for any help
Re: will not start
« Reply #1 on: 11 September 2010, 10:54:19 »
Is the 2.2dti not self bleeding?
Anymay, if you want to manually bleed, its undoing the pipes that run into the top of each injector (undo = loosen, just enough for a jet of diesel to erupt when cranking)
Welung666
Re: will not start
« Reply #2 on: 11 September 2010, 11:02:52 »
Yes they are self bleeding. Ideally you need to get the codes read as it could be a few things causing it not to start.
leedsleedsleeds
Re: will not start
« Reply #3 on: 12 September 2010, 15:39:30 »
thanks for advice,farther in law came round with decent jump leads and can off easy start,and the old girls going fine now,best start in morning i hope lol
harpersimon
  • Marlow, Bucks
  • Live fast, Die young - leave a good looking corpse
Re: will not start
« Reply #4 on: 12 September 2010, 18:49:58 »
tried a crank sensor?
