Author Topic: Wing advice please.  (Read 1538 times)
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
Wing advice please.
« on: 12 September 2010, 22:19:31 »
Was looking on Flea bay and came across a VAUXHALL OMEGA B FRONT RIGHT WING. Ad states it will fit all Omegas 1994 - 1999. Will this fit my 2003 CD Facelift thought I read they were all the same. Cheers in advance. :question
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
Re: Wing advice please.
« Reply #1 on: 12 September 2010, 22:31:50 »
Anyone
« Reply #2 on: 12 September 2010, 22:32:30 »
Same across the entire range :y
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
« Reply #3 on: 12 September 2010, 22:39:29 »
Just contacted the seller and they said it wont fit now am confused anyone else shed some light on this. Not that am doubting rob.
« Last Edit: 12 September 2010, 23:08:36 by Raymienets »
« Reply #4 on: 12 September 2010, 23:45:52 »
eBay seller is confuddled  ;) Both pre & post facelift cars share the same front wings ............ or so I/m told.  ;D ;D ;D :y
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
« Reply #5 on: 12 September 2010, 23:58:09 »
Thought I had read this on the forum but cannot find the thread. Dont wanna waste my hard earned cash if there is a possibility it doesnt fit.
Agemo
  • Cleethorpes
  • Insignia
« Reply #6 on: 13 September 2010, 08:48:17 »
All the wings are absolutely identical, the only difference is the rubbing strip. Wings are bolt on and a doddle to do. I have never dealt with the company, but apparently you should ask for Steve and mention OOF.  :y
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
« Reply #7 on: 13 September 2010, 09:00:39 »
How do you access the bolts at the bottom?
Agemo
  • Cleethorpes
  • Insignia
« Reply #8 on: 13 September 2010, 09:09:51 »
I can't remember how to get the bottom off, but I never had a problem. Perhaps you take the plastic sill off? I hope someone here has removed one recently and will advise.
« Last Edit: 13 September 2010, 09:10:13 by Agemo »
« Reply #9 on: 13 September 2010, 10:08:38 »
Courtesy of Welung "2 torx screws attaching the arch liner to the front bumper need to come out, then the arch liner. 3 x 10mm bolts holding the black bumper retainer then the 2 x 10mm bolts behind that. Line of bolts across the top (8 IIRC and all 10mm). Then 2 x 10mm bolts behind the sill cover, 1 x 10mm bolt at the top hinge edge from the door side and 1 x 10mm bolt about halfway up the hinge edge from inside the wheel arch."
« Last Edit: 13 September 2010, 10:08:56 by RobG »
Agemo
  • Cleethorpes
  • Insignia
« Reply #10 on: 13 September 2010, 10:55:25 »
There you go, I knew someone could help.  :y
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
« Reply #11 on: 13 September 2010, 10:58:46 »
Thanks everyone only problem with it was a slight colour variation which would be noticable on such a large panel. Anyone in Glasgow remove a slight dent LOL.
