Author Topic: stem oil seals  (Read 1684 times)
familymad666
  • long sutton,lincolnshire
stem oil seals
« on: 11 September 2010, 17:52:47 »
Hi everyone,
my eml light keeps comming on  >:(and fault codes keep pointing to bank 2 sensor 1 even thou i have changed one sensor and changed the others around 2 days later and light is on again. When the car has sat for a while and i start it up a cloud of gray smoke comes out the back end can this set off the eml light it only smokes on start up. If so is it the valve stem oil seals.Thank you for help in advance. :)
Ralph
  • Northumberland
    • 2.6 MV6
Re: stem oil seals
« Reply #1 on: 11 September 2010, 17:59:16 »
I've got the same Valve stem seal problem on my 2.6,
but it hasn't put the EML light on.
I think your problem maybe somewhere else.
Re: stem oil seals
« Reply #2 on: 11 September 2010, 18:22:28 »
It sounds like it. Mostly happens on 2001 2.6 cars
Re: stem oil seals
« Reply #3 on: 11 September 2010, 18:23:46 »
Sorry, should have said the smoke on start up if its a bluey colour is more than likely to be valve stem oil seals ;)
familymad666
Re: stem oil seals
« Reply #4 on: 11 September 2010, 18:27:19 »
Thanks for that i do not know what else it could be as all sensors have been tested with no faults , so valve stems it is.
familymad666
Re: stem oil seals
« Reply #5 on: 11 September 2010, 18:34:17 »
Would this smoke be the cause of the eml comming on.
familymad666
Re: stem oil seals
« Reply #6 on: 11 September 2010, 22:36:07 »
Does anyone know how long and what tools i need to change the valve stem oil seals as i will have to do to fix the problem of the eml light comming on.Thank you
Re: stem oil seals
« Reply #7 on: 11 September 2010, 22:38:04 »
I think the stem seals and the lamda fault are unrelated. Worth checking the wiring to the lamdas.
familymad666
Re: stem oil seals
« Reply #8 on: 11 September 2010, 22:51:16 »
I have checked the wires on the black connector under the car and are o.k all 4 sensors tested the same when it was at the garage i am a bit stumped with electrical as i am more machanical, where would i start looking code faults are 0150,0155 bank 2 sensor 1 even when i have changed the sensor Thank you,
tidla
  • solihull
Re: stem oil seals
« Reply #9 on: 11 September 2010, 22:53:15 »
anyone mentioned live data?
alank46
  • South Devon
    • 3L Elite Estate 1996
Re: stem oil seals
« Reply #10 on: 13 September 2010, 08:43:50 »
This is a very common incorrect assumption.
All that a fault code shows is that the signal received at the input to the ECU is out of the expected range.  It does not necessarily mean that the sensor providing the signal is at fault.  The sensor may well be working correctly and correctly indicating that there is a fault with the fuelling (or some other mechanical aspect of the engine) causing the lambda to be out of range.  It could also be faulty wiring or connections.
Somebody mentioned live data, seems like a good way to go.
Having said that, hasn't this age of car got 4 lambdas, and there is a known problem with the pre cat lambdas and a "how to" to fix it?  Something to do with moving them.  Don't know the details, my car only has 2 lambdas.
Martin_1962
Re: stem oil seals
« Reply #11 on: 13 September 2010, 10:46:33 »
Could it be sooty lambdas?
I had to replace my front ones
I replaced my valve seals with the green ones
Re: stem oil seals
« Reply #12 on: 13 September 2010, 12:46:05 »
Hi everyone,
What exactly are the codes?
Re: stem oil seals
« Reply #13 on: 13 September 2010, 12:46:58 »
Hi everyone,
Try the pedal trick if you don't have access to a reader.
