Author Topic: traffic master removal  (Read 1897 times)
hazpaker
  • deepest Norfolk
    • 2.2 petrol cd
« on: 12 September 2010, 15:01:04 »
can any one tell me  how to remove the now obsolete traffic master system from my car,thanks in advance. :y
Re: traffic master removal
« Reply #1 on: 12 September 2010, 15:03:12 »
I understand from others that it is not obsolete, with it still being used.  If you pay I think around £35 per year you can enjoy the service, which some rate! :D :D ;)
hazpaker
  • deepest Norfolk
    • 2.2 petrol cd
« Reply #2 on: 12 September 2010, 15:36:07 »
it is  obsolete in my car,i will never use it where i live or where i drive, i only use the car for work and local trips.
« Reply #3 on: 12 September 2010, 15:40:51 »
Remove trim panel from the pedal area and you should be able to see the black TM box (usually cable tied to loom) just a case of disconnecting
hazpaker
  • deepest Norfolk
    • 2.2 petrol cd
« Reply #4 on: 12 September 2010, 15:45:46 »
thanks rob,this will be a job for next weekend now i know were to look for the thingy. :y :y
SJKOO01
« Reply #5 on: 12 September 2010, 15:56:30 »
1. Remove the radio unit.
2. Then remove the radio cage, and unplug the multi-plug on the left of the cage, then the radio Ariel on the right of it.
3. Under the dash on the drivers side (on the left of the steering column) you should see a small box, just a bit bigger than x20 cig pack, with two white multi-plugs (black type), or silver type (think it has x2 multi-plugs & possibly small Ariel screw in plug?).
Now carefully cut any tie-wrap cables, and pull out of the way of its holder.
Unplug all the multi-plugs from this unit.
4. Back up to the stereo multi-plugs.  Now you need to pull out & towards you the plug marked 'B', though you may have to jiggle the other end a bit to get it to come out from the dash, as there are other cables in there to.
5. The original multi-plug 'A' can now be plugged back in to the radio cage, along with the radio Ariel. Now place the cage back in, then the radio.
6. Along the edge of the drivers side dash (at the bottom), there will be a couple of tie-wraps that need to be cut.
7. The panel on the end of the drivers side of the dash (you can't see it when the doors closed), carefully remove that.
Then the TM switch needs to be gently prised out away from it, and you'll then see the cable, as you pull it away, and with the panel removed, you can then have access to the plug if it snags on any other wires, and it should come out without too much problem ?.
Hope all that helps you out ??.  :y
hazpaker
  • deepest Norfolk
    • 2.2 petrol cd
« Reply #6 on: 12 September 2010, 16:04:17 »
just perfect - I knew it was a good idea joining this forum when i got my Omega , thanks a milion chap. ;D ;D ;D
« Reply #7 on: 12 September 2010, 20:38:43 »
And when you remove all the loom there are a few of us who wouldn't mind it (me being one ::)) :y :y
Tony H
  • liverpool
  • Black Elites are luurvley
« Reply #8 on: 12 September 2010, 20:42:53 »
As far as I know traffic master is still operative. As regards removal, isn't easier to just press the button to shut the tinker up than to go to the trouble of removing it  :-/
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #9 on: 12 September 2010, 20:50:34 »
It was active and working fine coming back from Newent last Sunday.
TuBy's new whipping boy.
« Reply #10 on: 12 September 2010, 21:08:44 »
LOL, theres me having to retro fit it back into my 2003 Elite ;D
« Reply #11 on: 12 September 2010, 21:12:13 »
Got a button with a T on it on the right of my dash. Think its  to do with TM but it doesnt seem to do anything  :-/
« Reply #12 on: 12 September 2010, 21:14:26 »
Possible someone has removed the unit
« Reply #13 on: 13 September 2010, 10:43:02 »
As we've said many times... TM is only good if you travel the main trunk roads a lot. Personally I wouldn't be without it  :y :y
« Reply #14 on: 13 September 2010, 18:19:37 »
I really miss it not being in my 2003 Elite.  I keep trying to retrofit it, but never seem to have access to the car ::)
