Pages: 1 [2] 3  All   Go Down
Author Topic: what is a powersounder  (Read 7120 times)
humbucker
  • Cambridgeshire
    • www.irmscherMV6.com
Re: what is a powersounder
« Reply #15 on: 12 September 2010, 15:42:33 »
You don't - just disconect the battery within 15 seconds of switching ignition off or powersounder will go off  :y
wow, that sounds like some fast work... those vauxhall/opel design chaps really were designing this thing for daley thompson and co.
stupid question perhaps, but what's the story if your battery is dead and therefore iginition won't go on in the first place?
« Last Edit: 12 September 2010, 15:43:54 by ilovemyelite »
PM with your requests.
dragonlord
  • luton
« Reply #16 on: 12 September 2010, 15:56:17 »
The powersounder is a back up siren in case some wee chav manages to get your bonnet up and disconnect your battery to stop the 'horn' alarm sounding. On disconnection of the battery, 15 seconds later the powersounder will sound.
If a theif sets off your alarm it will sound the standard horn, if they then pop the bonnet and remove the lead on the battery, the horn will shut up,so effectively not the best line of defence,so the powersounder will then sound 15 secs later as a backup.It is hidden in the scuttle panel and will not shut up...no theif is going to hang around long enough to try and silence it.
A good idea in theory,but as it battery powered(to still sound without the cars battery) it has led to dead batteries later in the cars life,it has also led to leaking batteries and even been known to set itself on fire
Mine never worked like that
the horn never sounded with the alame ever since iv had it
and the horn is 100% tested working and fine
always the siren would sound when alam was set of and battery disconected
untill it the nicad died and the siren/power sounder packed up
Were any of the omega`s wire different ?
mines a 1999 3L elite
IM trying to found out what the pin outs are on the power sound/loom
so i can figer out how to wire a better nicad free siren to the alam
does anyone know what the pins are on the plug that gos to power sounder?
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
« Reply #17 on: 12 September 2010, 20:18:57 »
If you leave the ignition on and then disconnect the battery the power sounder doesn't go off, I wouldn't advise that though.
If I need to disconnect the battery on a car with a power sounder I slacken the battery lead, then turn on and off the ignition, and then walk round to the battery and pull off the lead.
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #18 on: 12 September 2010, 20:25:22 »
The whole point of the power sounder is to go off if the battery is disconnected so a nicad free siren isn't going to be possible unless you use some other form of rechargable power pack.
If you want to put a siren on the alarm just use the alarm horn connections. Or you could just replace/reconnect the alarm horn under the scuttle.
TuBy's new whipping boy.
dragonlord
  • luton
« Reply #19 on: 13 September 2010, 06:38:47 »
you mis under stod me i think mine is wired different
as horn never went off when alarm did never has
but theres nothing wroung with horn and its working
i tested it
the power sounder use to sound with normal set off alarm and when you disconect the battery
since the power sounder dired last week
i get no alarm sound at all
alway when alam went off it was the siren only that sounded
thats the bit i couldent work out
im wondering if vx changed some of em
mine a 99 miniface lift
or there some fault with alam to horn wireing
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #20 on: 13 September 2010, 08:00:16 »
You are checking the alarm horn under the scuttle and not the main horns under the bumper aren't you?
humbucker
  • Cambridgeshire
« Reply #21 on: 13 September 2010, 09:52:36 »
what if the battery is dead already though, say a car has been standing for ages and battery has died, how do you work around that 'cos if the ignition won't go on in the first place i don't see how you can get this process to work. maybe i'm missing something. furthermore what if the car has no battery in it at all?  :-?
« Reply #22 on: 13 September 2010, 09:58:01 »
.... furthermore what if the car has no battery in it at all?  :-?
then the powersounder ni-cad will eventually go flat .......  ::)
Chris_H
  • E London/Essex UK
    • Jag XF Portfolio S 3.0D
« Reply #23 on: 13 September 2010, 12:14:58 »
i tested it
I think I agree with you.  My 2000 3.0 Elite only sounds the powersounder (piezo-electric thing) even though there is an electro-magnetic horn attached.
I do have my old powersounder in bits on my desk if I can answer questions about it for you.
« Last Edit: 13 September 2010, 12:15:20 by ChrisH174 »
First Vauxhall - PABX Cresta; Previous, previous Vauxhall - 3.0 12v Senator CD; Previous Vauxhall Omega Elite 3.0V6 Saloon Auto
Osprey
  • Redhill, Surrey
  • Drink up. The world's about to end.
    • 01 2.6 Elite saloon
« Reply #24 on: 13 September 2010, 12:34:26 »
So, to be clear, the Omegas that have Thatcham approved alarms (all of them?) all have four horns:
Two everyday ones behind the front bumper, operated from the steering wheel.
One main alarm horn, under the scuttle by the driver's side wiper, which is powerd by the car battery when the anti theft alarm is triggered.
Finally a fourth horn, the power sounder, also under the scuttle next to the main alarm horn, which is powerd by its own internal battery when the anti theft alarm is triggered but also when the main battery is disconnected.  This internal battery is recharged from the main 12V system until, after ten years ish, it gets tired and beeps its own horn after you turn the ignition off to let you know it is also fed up with life.   ;)
I feel like a military academy. Bits of me keep passing out.
dragonlord
  • luton
« Reply #25 on: 13 September 2010, 17:16:27 »
i tested it
YEP Thats just as mine is chris
was all ways the same
and also my power sounder is poted filled with some rubber stuff to brim
iv seen others say theres are to
proberly vaxhall done that later to stop try to stop warter getting in
so there near inposible to take apart and fit new batts in
the reson im trying to find out is
i do computer and electronics
if a can find out what the pin outs are are on loom end
i could proberly knock up a better loader siren from somewhere and make a back up cuircut for it and relocate it some where else where it not prown to so much to warter damage
i just come back from scrap yard as they had a amga in and i needed a caliper glig pin as when i when to do the pad I notice some one has bent it before iv had the car
proberly try to push piston back while hanging on one pin with opening the bleed nipple
and while there i picked up the bracket with alrm horn and power sound on it
i will proberly need charging  befor i can find out if its ok
but that one is poted with the rubber compound as well
has any one be able to get the rubber crap out with out damaging the board on the poted ones
dragonlord
  • luton
« Reply #26 on: 13 September 2010, 17:22:32 »
one other thing iv not had one iv took apart
but most are saying there nicads
if so it was a vaery bad idear on vx`s part becase of memory problem with nicad cells
im guessing that they are proberly Nickel-metal hydride cells not nicad as they do not suffer from short charge memory problem so much
but  that would be bad design
as the most sutable battery would have been a small sealed lead acid for back up
thhaswhy  most house alams use a sealed lead acid for back up beacause the constant chargeing in there design  makes nicads or Nickel-metal hydride cells unsutable for them.
I really would love to get my eyes on the alarm system  and power sounder schematic
« Last Edit: 13 September 2010, 17:28:00 by outlaw1234 »
« Reply #27 on: 13 September 2010, 17:27:46 »
There are pictures here of some dismantled ones (at least ones people could take apart) - along with some very burnt ones..
Of the ones that were dismantled, I believe this is the type of battery (taken from another post) that was contained within:
http://www.watchbattery.co.uk/shop/products/BRVR-150H.shtml
(3.6v NiMH cell, x2)
dragonlord
  • luton
« Reply #28 on: 13 September 2010, 17:40:51 »
yes that Nickel Metal Hydride cells not nicad
incildently all cell packs are made up from 1.2v cells
soldered togeather with tags in serise to make the right voltage pack then heatshrinked in to a pack
in the above case its a 3.2volt pack made from 3x1.2v=3.6v as there two there proberly wired the two packs on board to then give 7.2v fully charrged it would give out about 8. somthing volts
as wireing them in paralel would only give 3.6v but with duble the current proberly not enought voltage to drive the siren
if you couldent get the pack you can buy indervigual cells and mack up your own packs
what vx shoud have done is used eather a 6v or 12v small sealed lead acid as there more sutable for constant trical chargeing thant other cells.
Chris_H
  • E London/Essex UK
« Reply #29 on: 13 September 2010, 22:15:17 »
This is my old powersounder pcb.  Just air in the plastic case and leaky batteries.
I suspect the four pins are two for power and two for balanced comms.  One day will stick the 'scope on it.
The big chip is an obsolete micro-controller.
« Last Edit: 13 September 2010, 22:16:36 by ChrisH174 »
Pages: 1 [2] 3  All   Go Up
