Pages: 1 2 [3]  All   Go Down
Author Topic: what is a powersounder  (Read 7154 times)
dragonlord
  • luton
Re: what is a powersounder
« Reply #30 on: 14 September 2010, 06:44:18 »
intresting and a diferent design to the poted ones
that mostly surface mounted componants
from what rubber crap i could dig out of one of the knackered one
I could see more olfationed componaints ie normal 1/4 wat size resistors and 3 leg transisters rather than
surface mounted stuff  and the back up cells are more
penlight battery size
ill be happy if i can just get the hour working with the alarm
as the local scrots dont go near it since its on cam and  and me the dog went after a couple that tried nicking the petrol late one night
the rottie left a nice reminder for one of them  to remember by
chomping a chunk of ass when were jumping back over my fence
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
« Reply #31 on: 14 September 2010, 12:37:38 »
I haven't noticed any of the 'rubber sealant' stuff on my power sounder, it works perfectly or could be taken apart and studied...
http://www.omegaowners.com/forum/YaBB.pl?num=1283293138
« Reply #32 on: 14 September 2010, 14:08:49 »
I suspect the four pins are two for power and two for balanced comms.  One day will stick the 'scope on it.
The big chip is an obsolete micro-controller.
The four pins are +12v permanent, +12v ignition switched, ground, and a serial comms link to the main alarm / central locking ECU. :y
dragonlord
  • luton
« Reply #33 on: 14 September 2010, 15:13:37 »
yep that makes sence should be easy
to work out witch is witch with a volt meter and conuity tester
last one left will be the com line
thanks  kevin that was what i wanted to know
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #34 on: 14 September 2010, 15:36:35 »
Went to main dealer today new powersounder £61 plus vat
dragonlord
  • luton
« Reply #35 on: 14 September 2010, 16:50:51 »
well thats not as bad as i thort
Pages: 1 2 [3]  All   Go Up
