Author Topic: starting in the wet  (Read 1008 times)
leedsleedsleeds
starting in the wet
« on: 14 September 2010, 20:49:50 »
diesel car real pain to start in wet last couple off days.will fire at first then cut out,can onlly get her going by spraying easy start stuff direct into air intake pipe.runs fine once going,any ideas whats up please
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
Re: starting in the wet
« Reply #1 on: 14 September 2010, 20:51:42 »
you ought to keep that stuff well away if you want it to continue running.
cooler, damper mornings....sounds like the glow plugs are shot. ;)
« Last Edit: 14 September 2010, 20:52:51 by billthebrickie »
Welung666
« Reply #2 on: 14 September 2010, 21:05:48 »
DO NOT USE EASY START!!!!!!!!!!!!! It's like poison to a diesel!!!
A set of glow plugs will cost you less than £30.
leedsleedsleeds
« Reply #3 on: 14 September 2010, 21:11:01 »
glow plugs it is in the morning cheers,i`ll bin easy start
Welung666
« Reply #4 on: 14 September 2010, 21:12:28 »
Keep it, I use it to get grease off my hands ;D ;D
