Author Topic: 2.5td, anyone ried one of these???  (Read 3270 times)
dervdoc
  • Co.Armagh, N.Ireland
  • super turbo diesels
markspark
  • Bolton
Re: 2.5td, anyone ried one of these???
« Reply #1 on: 14 September 2010, 22:38:05 »
personaly no and no i wouldn't buy one i would do my home work on here 1st and see what comes up i think the boy is the one who has the info on the chips ect (if im wrong sorry) there are a good few on here that have used chips ect
scimmy_man
  • yorkshire
« Reply #2 on: 14 September 2010, 22:38:47 »
Mmm snake oil ;D
hoofing it
« Reply #3 on: 14 September 2010, 22:40:32 »
I'd rather buy from a member on here + there's three chips to choose from :y
scimmy_man
  • yorkshire
« Reply #4 on: 14 September 2010, 22:41:59 »
I had my dog chipped, its no faster.
dervdoc
« Reply #5 on: 15 September 2010, 09:12:39 »
what do you mean 3 to choose from? 3 different fueling maps or just different ecu types
hoofing it
« Reply #6 on: 15 September 2010, 10:17:45 »
as highlighted 3 different maps.  :y
unlucky alf
  • worksop, notts
« Reply #7 on: 15 September 2010, 10:30:00 »
I notice the seller states that no other mods are required, has he not heard of the inevitable AR25 self destructing gearbox episodes. :o :o
dervdoc
« Reply #8 on: 15 September 2010, 11:33:26 »
sounds good, i usually set the 325tds up with a chip then a boost controller set to 18psi for best results, so im sure the omega will be somewhat very similar as is same engine
alcutler
« Reply #9 on: 15 September 2010, 11:41:45 »
Check out the sellers feedback - hes got plenty mostly positive - you could even contact one of his previous buyers via ebay to see how they went on!
dervdoc
« Reply #10 on: 15 September 2010, 11:45:23 »
well iv pm'd ''theboy'' in regard to chipping so hopefully be able to sort something out there, keep it in house ya know
krivoyrog25
« Reply #11 on: 15 September 2010, 11:57:13 »
why don't you start with a BMW ECU, should give around 20BHP gain. The same engine in the BMW has around 150 ish BHP I believe.
You can maybe get cheap from the scrap yard.
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #12 on: 15 September 2010, 12:25:14 »
BMW designate this engine as the M51D IIRC; with 143 BHP on tap as standard.
It's detuned to 128 BHP in the Omega.
A 'Plus 5' chip (5%) gives you roughly 150 BHP therefore.
Cost's around 70 quid from 'our man' - see also:
http://www.omegaowners.com/forum/YaBB.pl?num=1232908603
« Last Edit: 15 September 2010, 12:28:10 by Reliance505 »
dervdoc
« Reply #13 on: 15 September 2010, 13:45:20 »
is plus 5 the biggest increase avail?thanks for the link, had seen it done when i got my 325td done.
« Last Edit: 15 September 2010, 13:49:12 by dervdoc »
« Reply #14 on: 15 September 2010, 14:15:33 »
Nope, no electronic boost control on the Omega (there wasn't on the same lump in the BMW and Ranger Rover either). Boost control only appeared with the 2.5 common rail  :y
« Last Edit: 15 September 2010, 14:15:59 by Mark »
