Author Topic: replace rear stabilizer bushes  (Read 967 times)
Boditza
  • Craiova, Romania
« on: 15 September 2010, 19:33:25 »
Can  anyone explain how can i replace them?? i can bearly stick my hands to them not to mention to unscrew the bolt.
i am talking about these
http://www.autokarma.ro/Pozasigla.aspx?ProdusId=877649
Re: replace rear stabilizer bushes
« Reply #1 on: 16 September 2010, 02:16:15 »
http://i.pbase.com/o6/69/14969/1/72707687.3zhI3wuQ.Omega_bRearSuspension.jpg
Was going to say drop the diff, as the spring replacement guide, but that won't help by the looks of this. :-/
« Last Edit: 16 September 2010, 02:17:31 by chrisgixer »
« Reply #2 on: 16 September 2010, 09:32:08 »
Thats exactly how you do it, not to hard  :y
In fact its often a bit easier as you dont need to drop it far to get at the U clamp bolts so the brake pipes dont need removing from their mounts
Boditza
  • Craiova, Romania
« Reply #3 on: 16 September 2010, 18:49:19 »
ok then.. how do i drop the diff?? isthere any guide to do it?
« Reply #4 on: 16 September 2010, 19:33:04 »
see the spring replacement guide in maintanance. Involves dropping the diff, which sounds drastic, but is actually quite easy with the guides help.
Actually, i'm being thick, again, i was thinking the spring guide involves dropping the diff, in fact its the whole subframe that drops to remove the springs. Which is exactly what you need to access the bolts roll bar bush bolts.
