Author Topic: HELP - Fuel filler cover won't unlock!!!  (Read 1652 times)
Neil_MV6
  • Sutton Coldfield-West Midlands
« on: 15 September 2010, 19:59:24 »
Stopped for fuel in Nottingham today before my drive home to Sutton Coldfield and couldn't open the fuel filler cover...it hasn't unlocked with the central locking.  >:(
Luckily I had just enough fuel to get home.
Is there a way to manually unlock it? Is there a specific fuse that could have blown or is it likely to be something to do with the lock itself?
charlie
  • sunderland
Re: HELP - Fuel filler cover won't unlock!!!
« Reply #1 on: 15 September 2010, 20:03:11 »
« Last Edit: 15 September 2010, 20:15:16 by charlie »
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« Reply #2 on: 15 September 2010, 20:04:18 »
probably the locking motor in the boot up inside above the inner arch.
davethediver
  • Blackburn, Lancs.
« Reply #3 on: 15 September 2010, 20:07:41 »
OPen the little first aid compartment you will see the locking motor disconnect it you can try and fix it with some lube.
I threw mine in the bin and bought a known good one for a fiver fit that job done :y
P.A. Caron de Beaumarchais
Neil_MV6
« Reply #4 on: 15 September 2010, 20:47:43 »
Cheers guys, just found my manual and spotted it too.
Thanks for the replies!  :y
« Reply #5 on: 15 September 2010, 20:55:55 »
Wiggle the leads to the connector and work it a few times.
The wiring can get knocked when things get chucked in the cubby holes
Neil_MV6
« Reply #6 on: 17 September 2010, 09:25:22 »
I did a wiggle of the wires and it worked but only intermittently.
Will get it out tomorrow and give it an 'overhaul'.  :y
« Reply #7 on: 17 September 2010, 10:04:45 »
Got a spare here if needed :y
