Author Topic: Adjusting the headlight washers  (Read 1077 times)
Kaycee
  • Doncaster
« on: 17 September 2010, 07:17:19 »
hi could any one advise me how to adjust the headlight washers as my passenger one is going straight up i cant see any way to move it
thanks
There is a tide in the affairs of man if taken at the flood will lead on to greater things
Re: Adjusting the headlight washers
« Reply #1 on: 17 September 2010, 10:44:56 »
They are a ball in effect, with slots around the jet hole, a similar sized flat blade in the slots and use that to leaver the position down, best not to poke anything in the jet hole, they are only plastic and the jet shape will deform quite easily, not that that's problem on headlight washers as such, just that they use a small lake of fluid every time as it is.
Dave Elite
  • Ellesmere Port
« Reply #2 on: 17 September 2010, 11:04:05 »
If you make the jet whole bigger, you would not use any more fluid because the pump is on for the same amount of time pumping the same amount of fluid. It would spray less powerfuly though.
